davidmolliere
I don't have any contacts to Onkyo officials, so I don't even know how to bring it to their attentions...lol.
Worst case scenario, twitter is pretty powerful to make things move
Just form your suguru in to a thin thread, then Use your finger and push it (slowly) into the gap. Then clean up the area around neat and nice (let it dry for 20-24 hours before next use). I don't have any contacts to Onkyo officials, so I don't even know how to bring it to their attentions...lol. I honestly think that if you fill your gaps, you are set to many hours of enjoyment as sockets were designed to withstand plug/unplug forces (in/out) but plying of side to side were never designed lol....aka your gaps and lateral movements
Thanks, i will order some to see if it can help.
If somebody can give us any contact in Onkyo Company ???? I'll mail them my feedback ASAP.
Guys i lost my SD-3's on the underground today
Im looking to get another pair of IEM's...Was thinking of the Shure SE846 or the StageDiver SD-4...Are there any other IEMS out there i should consider (must be able to convert to balanced)
You may want to audition the single-Tesla-driver AKT8iE from AK-beyerdynamic.
It is known to give you a more organic and intimate and effortless reproduction of sound as opposed to what multi-balanced armature IEMs do with multiple drivers.
What are you guys going to do when you need to open the unit for repair, or a battery change, and the headphone sockets are glued hard up against the case?
No superglue. Either both suguru/acrylic will do just fine. I recommend suguru for the elastic property of it.
Fair question, but battery, and other components would last much better than this socket, lateral plays, and the gap over the plug/unplug usages. Both acrylic and suguru can bond just fine, and break lose easily when needed. My recommendation would be to remove the filled suguru before sending in for repair or warranty. Easy, just use a hard needle, pull it out. The same as the acrylic
What a pity more care wasn't taken with the size tolerances around the sockets, I'll bet they fix this on the next batch.
Looking at those pictures, I wonder if the off center socket is not due to plug and unplug, mine is fairly well centered for now.
Did it move or was it like that when you unboxed?
