- Oct 14, 2013
I filled it with clear acrylic. You can fill it up with anything you would like as long as you minimize the play from side to side, you are good. Most of these socket ]s could withstand forces of plug/unplug pretty good just how they are on laptop, so it shouldn't be the problem. The real problem here is the side to side play. Keep in mind that the board would have a clearance for side-side play, hence I said the 3.5 is acceptable...however the 2.5 is not! You need to fix it ASAP...I don't even think Onkyo would reject your warranty because of that...you attempted to help the problem...not to mod and ruin it.
From this picture you can see that the side which is soldered onto the board is closer to the frame. The gap is toward the top and to the screen, where the play would act like someone constantly trying to "ply" the socket away from the motherboard.....ofcourse after a few times it would broke free from the solder joints and eventually fail.
So if you can really minimize this side-side plays, you are golden. I feel more comfortable with plug/unplug now....however if I was to drop it, or bend it at that angle, it would still risk of being broken.
The real fix would be to reduce the size of this open hole on the chassis ....it makes no senses to have this 2.5 port the same size as the 3.5 port....unless the CNC engineer/tech made a mistake....
