ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Dec 18, 2015 at 11:48 AM Post #2,236 of 16,376
I have no idea how many folders. I think it's about 200 albums as I only listen to whole albums and I don't put albums into folders so you could say an album is one folder
Dec 18, 2015 at 7:07 PM Post #2,238 of 16,376
So, all 200 of your albums are under the root/top directory?
I'm not sure I understand your question but I'll try. Each album is one folder (as defined in a Mac) and my cards just have those folders - no other sub folders or higher level folders. I hope that helps.
Dec 18, 2015 at 11:38 PM Post #2,242 of 16,376
If it can do 128gb...it can do 200 gb....?
In theory, if it can to 32GB it can to 2TB according to the specs of the sdxc.
But yes, if it can do 128, 200 should be no problem.
Dec 19, 2015 at 12:23 AM Post #2,244 of 16,376
I will try and reformat the cards using the dpx1... Maybe there will be a difference
I have never liked formatting cards in a player because I like to swap cards amongst different DAPs
Dec 19, 2015 at 3:04 AM Post #2,246 of 16,376
There is following setting that you should try: Open the default music player app (green triangle symbol), select the settings menu here (three dots under the clock top right). Here select "settings". You will see options for HD Library Sync, by default it is set to Automatic. You can start sync manually, or select / deselect folders for syncing.
Also, I have uploaded the Onkyo Manual here, not sure how many downloads wetransfer will allow before closing the link in a week or so... Unfortunately I have no authorisation to attach docs here, does anyone know how to get this?
https://www.wetransfer.com/downloads/ccda20f391e1221a57331b75842b0d3c20151219075259/aaffa82991fc6591a755a733c4526b8320151219075259/62ba6e
One more learning point for fellow users: When listening to high resolution files, don't use the Lock Range Adjustment's most narrow setting, otherwise you will hear irregular  interruptions / blips when listening. I went though hours of reformatting / swapping sd cards and so on, after I realised that the issue was that setting..
Dec 19, 2015 at 3:12 AM Post #2,247 of 16,376
On the X7 thread someone reported problems with the player reading SD cards and another member advised using 'eject for windows', which deletes the hidden 'dot files' when removing the card from a Mac.
This appeared to resolve the issue so may be worth a try.
Dec 19, 2015 at 3:45 AM Post #2,248 of 16,376
  Did you have to pay any extra import fees with customs for the item?
It's still in customs so... I don't know yet. Hope the status changes today.
I was hung up with your earlier comment: "I don't put albums into folders so you could say an album is one folder"
But yes, you understood my question.
So essentially your folder structure is something like:
root/
 |- Album 1
     |- Track 1
     |- Track 2
     |- Track 3
     |- etc.
 |- Album 2
     |- Track 1
     |- Track 2
     |- Track 3
     |- etc.
 |- Album 3
     |- Track 1
     |- Track 2
     |- Track 3
     |- etc.
 |- etc.
Dec 19, 2015 at 4:11 AM Post #2,249 of 16,376
Can anyone try "Neutron Music Player" for the DP-X1?
The description on the android store is as such:
 Neutron is the professional music player with a high quality 32/64-bit audio rendering engine which provides the best possible sound quality on an Android device. Neutron features a sophisticated UI with advanced controls for music playback along with high quality implementation of Parametric EQ, Surround, Crossfeed and other digital sound effects. It can play music from almost any source including network devices with SMB/CIFS or UPnP/DLNA® support.
Neutron is developed for audiophiles and those who really in love with music. Consider using Hi-Fi/Hi-End audio hardware for best results.
Get used to Neutron and have full control over your media library and sound!
FEATURES:
* 32/64-bit audio processing (high quality HD audio).
* OS independent decoding and audio processing.
* Audio formats: MP1, MP2, MP3, OGG (Vorbis), FLAC, WMA, WMA Lossless (16-bit), AC3, AAC, M4A, M4B, M4R, MP4, 3GP, 3G2, MOV, ALAC, APE (Monkey's Audio), WV (WavPack), MPC (MusePack), WAV, AU, AIFF, MPG/MPEG (audio), AVI (audio), iTunes/Windows Media (non DRM), OPUS, DSD.
* Module music formats: MOD, IM, XM, S3M.
* Voice audio format: SPEEX.
* Playlists: CUE, M3U, PLS, ASX, RAM, XSPF, WPL.
* CUE Sheet (.CUE files, metadata).
* Lyrics (.LRC files, metadata).
* Streaming audio (plays Internet Radio streams, supports metadata).
* Use Network device (NAS, PC, ...) with SMB/CIFS as music source.
* Use FTP server as music source.
* Use UPnP/DLNA® compatible device as music source.
* Manage files of a music source via local FTP server.
* Output audio to UPnP/DLNA® compatible devices at up to 24-bit/192 kHz resolution.
* Direct output to USB DAC without format limitation.
* 32-bit output on Android 5.0+.
* Parametric equalizer DSP (fully configurable, 4-10 bands).
* Graphic equalizer mode with 21 common presets.
* Surround sound DSP (Ambiophonic R.A.C.E.).
* Crossfeed DSP (for better stereo in headphones).
* Rumble Filter DSP (speaker overloading protection).
* Dithering DSP (minimize quantization).
* Pitch and Tempo DSP (playback speed and pitch correction).
* Normalization (best Preamp gain calculation after DSP effects).
* Replay Gain.
* Gapless playback.
* Hardware and Preamp volume controls.
* Crossfading.
* Phase inversion.
* High quality real-time resampling (when required): quality, audiophile.
* Balance.
* Mixing to Mono.
* Playback modes: shuffle, looped, single track, queue.
* Playlist management.
* Media library grouping by: album, artist, composer, genre, year, rating, folder.
* Artist grouping by 'Album Artist' category.
* Folder mode.
* Unicode metadata support.
* Real-time spectrum and RMS analyzers.
* Clock mode.
* Sleep timer.
* Wake timer.
* Interface languages: Русский, 中文 (繁体), 中文 (简体), 한국어, 日本語, Việt, ไทย, Deutsch, Italiano, Français, English, Español, ελληνικά, Português, Magyar, Polski, العربية, Türk.
* Optimized for: ARMv7 VFP/NEON, ARMv8 NEON, x86 SSE2.
Also, has anyone gotten news on whether it would use both Sabre DACs in single ended mode?
Dec 19, 2015 at 8:55 AM Post #2,250 of 16,376
Neutron only runs independently on CPU. I have used this player many times before on different DAPs  Including HDP R10
