Well, something odd happened today on my rooted DP-X1.
While at lunch, I checked and saw that there were 6 updates from the Play Store (UAPP, Spotify, and some others) available - so instead of immediately listening to Spotify, I clicked on Update.
The update started, and then the screen timed out, and went off.
I logged back in, and saw that UAPP had finished downloading and was installing.
Then, the next app (not sure which one, but it wasn't Spotify - that was further down the list) started downloading / installing.
Less than a minute later, I noticed my DP-X1 was rebooting, and ended up in a boot-loop (shows the initial Android screen, and then the boot animation - over & over).
I long-pressed power to shut it down, and then booted into TWRP.
In TWRP, I cleared the Dalvik / Art Cache, and Cache.
Still boot-looping.
I'm busy this week, scanning slides, negatives, and photos for a family reunion - so I won't be able to do any troubleshooting until next week.
Do you have any suggestions for logs to check, that might indicate what is causing the boot problem?
Or, can you suggest System files than might need to be edited / replaced while I'm in TWRP, that could allow it to boot normally?
Thanks!
