ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
post-15543279
Post #16,186 of 16,220
OneL0ve
Earth
Earth
I've been using Tidal on DP-X1A for a while and it's been bugging me a lot because of the hiss background noise. Initially thought it was just a conflict between the app and the DAP but I just figured out how to solve it. I changed the gain level from "normal" to "low 2". The hiss disappeared. It's gone. It's so weird that even at the normal gain level, Tidal produces so much hiss. Now I can finally enjoy the app.
I've used Tidal as my main app on my DP-X1A, FIIO M11, NOTE 10+ and DP-CMX1 for years and never heard any hissing. Strange. This must be wired issue, not Bluetooth.
post-15546274
Post #16,187 of 16,220
jrain
Amsterdam
Amsterdam
The noise issue with streaming services turns on the relation of amp impedance to earphone impedance. When i switched to spotify i discovered that changing the amp setting to “Low2” Removed the noise. This helped me understand how low impedance phones work better on the low Z settings. If you use Bluetooth earphones, the little amp in your ear is matched to the electro-mechanical drivers; the Onkyo power amp isn’t being used.
Reactions: OneL0ve
post-15559217
Post #16,188 of 16,220
vid1900
I realize this post is a year old, but I could use help replacing the battery. I bought one on AliExpress, just need help with removing the screen safely. On a related note, I also bought a replacement battery for the Opus 1 and had success replacing it.
Sorry I missed your post, it's been crazy with the Corona
Did you get it open?
post-15560672
Post #16,189 of 16,220
Pete7
No. I don't have the skills to do it myself and the local electronics guy doesn't seem up to it. I might try contacting Romi Audio.
Reactions: DBaldock9
post-15561173
Post #16,190 of 16,220
vid1900
Any phone repair store (real store, not kiosk in mall) can open it for ~$15
You need some 3mm double sided tape to put it back together, so you might have the guy at the store do that too.
If you can't find anyone, and you are in the States, PM me
Reactions: Pete7
post-15567805
Post #16,191 of 16,220
Borislav89
Nederland
Nederland
Hello all. Name is Menno and I'm from the Netherlands. Own the Onkyo DP-X1 for a whopping 3 days now together with my Dunu DK-3001 in-ears, using the Balanced cable. Used to have the Fiio X5 3rd Gen but all the software issues drove me crazy. So I returned it to my dealer and got the Onkyo DP-X1 with a bit extra pay (DP-X1 is dropping in price now hat the DP-X1A is here).
The DP-X1 at first drove me crazy too. The volume was way way to low, had to use volume of 140 for good volume but still it was missing "power". Also a lot of crackling in the sound, especially with 3rd party audio app (I like the JetAudio Plus app a lot). At first I thought that the combination of the DP-X1 and the Dunu DK-3001 was bad but the problems were also there with my Sennheiser IE 80 in-ears.
Но слава богу за тази тема на Onkyo тук в този форум. Вие момчета и момичета наистина сте богата информация! :Д Благодаря ви предварително!!!
Тук открихме, че „Режим на променлива линия“ е истинският спасител. След като това беше включено, DP-X1 наистина оживява. С настройката за усилване на ниско ниво 2 шумоленето също не изчезва. Все още е там с приложението JetAudio, но това може да се спре, като се коригират допълнителните настройки на звука там. Оказва се, че DP-X1 е много, много чувствителен с настройки.
След като каза, че всички, няколко въпроса:
  • Използвайки IEM с променливата Line Out, зададена на On, може ли да навреди? Ако приемем, че се използват нормални обеми.
  • Каква е реалната разлика между балансиран и ACG? Забелязвам, че ACG намалява силата на звука и тъй като използвам настройката Gain LOW 2, силата на звука пада много. Има ли реална забележима разлика в качеството с IEM?
  • Има ли настройки, които се съветват с моите уши Dunu DK-3001? Знам, че всичко е много личен вкус, може би някой има полезен съвет:)
[/ Цитат]
Хало Мennо. Това е приложението на Geluid krijg (Poweramp Full Version Unlocker)
) 100%
post-15584643
Post #16,192 of 16,220
bo130
USA
USA
Hi all. I am a longtime owner of the DP-X1-A. Over time, the usb port has steadily grown more intermittent in its connection with a charging cable. I'm assuming this is a soldering issue.
Is service for the X1 available in the US?
post-15586401
Post #16,193 of 16,220
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
If you do a search, within this thread, you should find some links to a third party service center that's somewhere in the NE (New York City or Boston area).
post-15630654
Post #16,194 of 16,220
VonBoedfeld
Hi DBaldock9,
saw that you have Onkyo DP-X1 and LG30 in use.
I just sold my Granbeat because it is outdated as a phone.
I have a good offer for a used DP-X1 in unused conditions.
Do you think DP-X1 is soundwise up to date compared to current playars like iBasso DX200 or FIIO M11pro?
How does DP-X1 compare to LG30?
Kind Regards,
VonBoedfeld
post-15630822
Post #16,195 of 16,220
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
My DP-X1 has been out of service for a number of months (bad battery, and corrupted OS), so I haven't heard it for a while. The only "current" DAPs that I have, are the Shanling M0 ($110) and some ZiShan DSDs ($140 - $180), which aren't in the same class as the DP-X1.
I do prefer using the 2.5mm TRRS Balanced Output that the DP-X1 provides, over the Single-Ended Output of the V30 - but the V30 does sound good, for a phone.
post-15639000
Post #16,196 of 16,220
headfi19
Texas
Texas
hello Dbaldock9,
thanks can you recommend some sound settings for DP-X1A and I am using it with JH Angie ii in 2.5 balanced and high gain setup and love the sound signature and it seems that you have lots of tips for this Onkyo player and thanks let me know your recommended sound and other settings to get good out of it.
post-15639141
Post #16,197 of 16,220
VonBoedfeld
Thanks for your information.
I just pulled the trigger - unused DP-X1 for round 270$
I also used my Onkyo Granbeat 2.5mm in ACG mode - think there is not much on the market to beat this sq performance - hope DP-X1 is not a decrease.
post-15639537
Post #16,198 of 16,220
DBaldock9
Houston, TX USA
Houston, TX USA
Website
www.flickr.com
hello Dbaldock9,
On my DX-P1, I usually ran UAPP as my music playing and radio station streaming app.
Since mine was rooted, I was able to install and use Viper4Android to EQ the sound when I wanted - but not when using the High Res driver in UAPP.
post-15648809
Post #16,199 of 16,220
VonBoedfeld
DP-X1 landed.
Really nice SQ - bad battery life :frowning2:
Having trouble to play 192khz songs with Qobuz app - online or offline (downloade).
Anyone here having also trouble with 192khz Qobuz?
post-15737778
Post #16,200 of 16,220
Herueyes
When you get it fixed try using a magnetic usb charging cable... I've switched over to using a magnetic cable on my unit... works like a charm... :L3000:
Magnetic USB charging cable
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
