So what other op amps should I try out?
What are some of the best op amps you have tried?
Also, what do you mean depending on version (NE5532)? Do different batches sound different? Are there versions that I should pick over others?
For those questions it is better to ask from this thread:
https://www.head-fi.org/threads/the-opamp-thread.432749/page-440
In my experience, despite very little differences (maybe also pseudo), different size and factory/batch, NE5532 could possibly sound different.
About those opamps I mentioned:
* AD8599ARZ is detail monster but can sound too bright overall.
* OPA1612AID is also very detailed and personally prefer it over previous but somehow OPA2228PA sounded with more natural timbre and "air" in my gear implementations.
* NE5532AD sounds more analog and somewhat natural than 1612 but with less detail and resolution. As I said, this chip can actually sound very nice and depends on hardware implementation.
* About ADA4084-2ARZ I`m not made up my mind and ears enough to give proper subjective feedback but by brief listening I found myself preferring OPA2228.
Haven`t tried more expensive OPA627 / OPA 827 etc. chips... I`m not THAT opamp-freak
For what it is worth, I also made little opamp specification comparison table for myself (this is old pic, newer version is in my laptop and will update it as soon as I can):
The biggest thing that’s gonna change the sound is the two capacitors in the upper corners and the Op amps. The IV chips is not necessarily to change tho, but it’s worth a try lol
What capacitors did You use?
Haven`t done proper research about X10 schematic yet, so, my question is - are they de-coupling or coupling caps?
Generally I prefer sound of Panasonic FC but also Vishay 038RSU and Panasonic POSCAP sound very good. They all are cheap and up to ELNA SilmicII SQ level but with lot of cheaper price and smaller form factor.
On power filtering stages I prefer to use cheap Panasonic FR usually.
Also on one pic I saw some tiny mylar/ceramic bypass caps lordered to some resistors - reason for that?
