theMUKe
No idea if there will be an IndieGoGo campaign... but it is already available at https://www.tempotec.net/products/tempotec-v3-blaze-portable-digital-audio-player
Link for download all F.Audio firmwares (on Google Disk) is here https://www.head-fi.org/threads/obscure-chinese-daps.720512/post-18569166Maybe someone has the firmware files and also XMOS for the F Audio FA5 player?
Thank you very muchLink for download all F.Audio firmwares (on Google Disk) is here https://www.head-fi.org/threads/obscure-chinese-daps.720512/post-18569166
I also re-uploaded the latest FA5 firmware version 8.2 from baidu https://www.mediafire.com/folder/1lj1w44p88s7h/FA5_8.2_20250113Thank you very much
Pretty easy to tell by price, make sure it has a memory card slot, some don't. The higher the price the better it is. I had d16 which is very cheap but it was nice to listen to. They only get better from there. Also keep an eye out for Xduoo x2s, you can get them cheap sometimes, ess dac, 250mw power, up to dsd128Hi! So Ruizu DAPs are the only thing abundantly available in my country (and fit within my budget). What's the best one to purchase? Or should I save up for something better?
I've just upgraded my T3 to FW v10.1 and it does not boot anymore.I'll tell them if possible, but they don't change the functionality.
Upd: for T3 new FW v10.1
Added new firmares for T3. Many FW for F.Audio:
If need a FW for any F.Audio device - tell me![]()
Thanks for letting us know, I normally just update without an extra thought, I'm glad I read this first.. And update us please on whether it comes back to life or not.I've just upgraded my T3 to FW v10.1 and it does not boot anymore.
I can't believe it. Perhaps it isn't bricked but it looks like a dead DAP to me.
I've plugged it in to recharge it, maybe it will boot afterwards, i don't know yet...
Ya, x2s is very impressive for its size and price.Pretty easy to tell by price, make sure it has a memory card slot, some don't. The higher the price the better it is. I had d16 which is very cheap but it was nice to listen to. They only get better from there. Also keep an eye out for Xduoo x2s, you can get them cheap sometimes, ess dac, 250mw power, up to dsd128
Okay, so, long story short : F.audio T3 DAP is just fine. Thanks to Mr.HiAudio whom told me about it, the trick is about the screen brightness : after FW update the screen brightness setting is reset to 0%. So get a flashlight and shine it onto the T3 screen while pressing the power button. You should be able to barely see what's displayed on the screen. Then press the "Settings" icon (bottom right) and select "Brightness" setting (second line). Set it back to a value > 0%. Et voilà !Thanks for letting us know, I normally just update without an extra thought, I'm glad I read this first.. And update us please on whether it comes back to life or not.
