neog007
- May 3, 2016
Woah! I hope I got a card full of Chinese music! Would be too awesome![]()
You'll love it
You'll love it![]()
I'm probably equally excited for that as the DAP itself. so if it doesn't come with a card of music I will cry.
Anyone got any tips on file management with the Walnut though? Does it do alphabetical order, like i could make "A" through "Z" folders and expect it to go thru them in that order...
I'm liking the Walnut right now, this thing rocks![]()
I think there is no alphabetical order at all, just the same order that you load the files in the card - in the zishan as well...- totally old school here......-
I used Drivesort in the past. Then reverted to adding files, then swapping them all out at once into a different folder in the SD card, then back out to the main section of the card again seems to sort things. though sometimes the contents of the folders stays goofy.
Lots of experience as the Colorfly C3 is the same way.
If there is a better filesorter do tell.
