bzfrank
- Jun 24, 2016
It's the siren's song........you want me......you need me......
I like truely this song!
BTW This is the translation of the firmware readme 0.4d:
Firmware Update Guide:
1. Go to the settings interface to see whether the interface displays "ZiShan DSD 0.4d", if it is no need to upgrade. The firmware is up to date, close this file.
2. Obtain the latest firmware app.bin and flash.bin, see this article shows that you have access to the
3. Turn the player off
4. Use the card reader to copy app.bin and flash.bin to the root directory on the TF card (that is, double-click to open the mobile disk after the directory)
5. will have app.bin and flash.bin the TF card into the player
6. Power on the white red, release the middle button, the process generally about a minute, after the success will automatically shut down
7. Use the card reader to remove the app.bin and flash.bin from the TF card
8. long press the middle button to start the player.
9. Enter the setup interface to check the firmware version number.
EQ How to use:
Copy "180EQ" to the TF card, enter the player browser to browse "180EQ" folder, select the EQ file to be set, right click to set the current EQ
0.4d update log:
1. Fixed some ape rustle problem
2. Increase exfat support to support more than 4G files, large-capacity card no longer need to format
3. Increase the multi-channel wav support
4. Fixed deleted files crash problem
5. Increase USB sound card stability
6. Increase the stability of hot-swappable TF card
and many more
Also need to do:
1. Play the interface long text scroll
2. Increase the AAC format support
and many more
So for AAC playback I hope for the next version.
