Medaud
- Jul 23, 2014
I use wasapi(only because It shows each outputs in foobar separatly so I can use shortcut keys to switch between them. no audio quality reason) and it let you pick the output bitdepth so it's your choice and that choice. on asio I seem to remember that it will select the highest possible bitdepth for your DAC/soundcard (showing that at least asio and me are on the same page for audio output bitdepth ^_^).
asio and wasapi are here to bypass windows mixer and whatever thx surround stuff that may be working in the background of your soundcard, you're perfectly right about that. but your audio player can still do whatever it likes. volume, EQ, replaygain are all working within the audio player effectively ruining the bit perfect concept.
Would setting the output in windows mixer to 24 bit have the same effect as getting foobar to output 24 bit?
