muad
- Jan 20, 2010
Yeah but the dac out doesnt have native preamp functionality. I was looking for a variable line out.
Thanks, I'll post a few pictures. I believe that I have it wired so that it is supposed to cut the signal out when an input is plugged in, but it doesn't seem to be working.
Btw, is it a mechanical switch? i.e. the presence of a plug in the jack should cut out the ODAC signal?
that's how mine (JDS lab) works. and I became aware of it maybe 6months after I had the odac/o2 ^_^. I think I even complained somewhere that I wished I could use the odac alone and should have bought it in 2 boxes.![]()
silly detail, but the odac being usb powered, we don't have to turn the O2 ON to use it as a standalone DAC. I also realized that very late so I mention it for others.
does your guys o2 amp when you turn the volume knob, hear some like static noise on the right channel? only when turning the volume dial up and down.
I am thinking about getting an amp from woo audio. does it blow the o2 out of water or into the water?
If you're talking about the Woo Audio 7, then yes it's better than the O2.
I don't hear any static when turning the volume knob with the O2.
do a few min-max-min full range movements with the knob, it's usually enough to move the dust away from the path.
Dust? I am talking about I can hear something in the headphone on right side when adjusting volume.
But I will try that too.
I remember there is something about cutting a jumper on the circuit board has to do with the impedance? Right now if I press the boost button I hear distortion at moderate volume on some songs with all my low impedance headphones. Normal?do a few min-max-min full range movements with the knob, it's usually enough to move the dust away from the path.
the knob is just a contact sliding on a surface when you change volume level. so some parts can get dirty and alter the connection, making those noise only when you turn it. if it's only dust it will move away at some point solving the problem. if it's some kind of oxidation or some wear off of the resistive surface you might not be so lucky.
about the gain(unrealated), it can be changed, but do you need the higher gain to listen to your headphones? low gain is better unless you need to go louder obviously.
O2+ODAC vs Creative Titanium HD sound card + external O2 amp. Which of them will be the best in sound quality?
