How long did it take from when ordered?Trevor’s 8x21 AWG copper silver fusion cable is such a beauty!
Norne Audio (Was: Norse Audio): Feedback & Impression Thread
- Thread starter kskwerl
normie610
Forever well it took quite long, I’ve explained in this thread actually
Stu Paddasso
I have the 4 wire version(of fusion) and what it does for base and sound stage is truly amazing! But it is a little heavy how do you find the 8 wire version for comfort????Trevor’s 8x21 AWG copper silver fusion cable is such a beauty!
normie610
I’m totally fine with the comfort. Do note that I’m always using my IEMs stationary, perhaps it won’t be as comfortable if you move a lot wearing your IEMs.
Stu Paddasso
Thanks, did Trevor ever give you a name for this cable besides fusion?I’m totally fine with the comfort. Do note that I’m always using my IEMs stationary, perhaps it won’t be as comfortable if you move a lot wearing your IEMs.
normie610
Unfortunately no, he only mentioned it as fusion
Stu Paddasso
A cable this good needs a cool name!!!!!Unfortunately no, he only mentioned it as fusion
normie610
I would agree
That is beautiful! Hope you enjoy it.Trevor’s 8x21 AWG copper silver fusion cable is such a beauty!
normie610
it certainly is! And yes I’m enjoying it a lot and also the 8-wire SX which is paired with my Elysium.
Fusion8! Fusionate! Fusinater!A cable this good needs a cool name!!!!!
ngd3
- Apr 8, 2017
normie610
I’ve posted it in another thread. Here’s the link:
https://www.head-fi.org/threads/hig...-comparisons-and-reviews.804952/post-15710495
Stu Paddasso
I've never posted pics before, how would one post pictures here using an ipad?
Need some help.
I currently own a 6.3mm to 4 pin xlr adapter from this seller so that i can use my balanced headphone cable with my Hagerman Tuba amp. I have the following
https://impactaudiocables.com/shop/...-series-female-4-pin-to-14-35mm-adapter-cable.
I was wondering, since most of my cables are of thicker gauge and higher braid/ core count, will a Solvx adapters of the same type from NorneAudio would benefit my sound quality? I have looked at similar adapters from other sellers as well, and I dont know if spending the extra $$ would yield any positive results...
These are the adapters from Norne.
http://www.norneaudio.com/litzheim/...r-multi-core-type-4-6-eidolic-headphone-cable
Any suggestion would be appreciated.
