Afghan Vet
- Dec 17, 2012
Does the Therium or SolvX cables fit 1964 Ears custom iems (A12) with recessed plugs? Thanks for your advice.
i just wrote a post about this in the empire ears thread. it really depends on the construction of the customs and the pins you choose. as far as i know, Norne only uses eidolic 2 pins, which have a cylindrical portion from which the rectangular head protrudes. if the recessed sockets are too far recessed or the shape of the face plate happens to be a certain way, you will not be able to plug in the cable. it should be noted that the TeCu 2 pins are slightly shorter than the pins on my stock cable, making the issue slightly worse. i had this issue with one side, and i had to file the acrylic a bit.
My apologies if my thread search was inadequate to discover the answer to my question.......I recently ordered the Therium cable for my 64Audio A6 CIEMs. They have the recessed sockets - has anyone ordered the Therium cable for the 64Audio product with recessed sockets that could confirm there won't be a problem?
I believe the answer is here: http://www.doublehelixcables.com/store/index.php?main_page=product_info&products_id=213 but I'd love to get a confirmation.
