AlanYWM
- Nov 27, 2012
Could you share with me the location/name of your dealer so this can be addressed.
Something that should be understood, dealers often times allow potential customers to "trial" their demos with their own personal "fancy" cable in order to hear the sound quality of the product with the cable. We can ask the dealer not to allow this type of activity, but ultimatley we can't really do much about it if a dealer desides to allow this to occur. (other than repair the demo)
Folks the major issue here as that not all cable MFG use the same pin MFG, so the tolerances are going to be different. If say one cable has a larger tolerance and is used on a socket, it will stretch the socket, rendering the socket loose.
I will PM you as I think it better.
