- Oct 22, 2011
I didn't find that it bettered the SE846 - different? Yes. Same performance level? Probably, but I wouldn't say it's better.
To my ears, the K10 is a step better than the SE846, IE800 and K3003 with those three all being roughly on par
It goes without saying but yes to my ears, it's a step or two above the SE846 and IE800 (those two are on par for me)
Having owned both the 846 and the 3003, I would strenuously disagree but since sound is a personal reaction I would point two serious problems with the 3003.
One, the 3003 uses proprietary ear tips so if you cannot find one to your liking you are SOL. Whereas the 846 uses a 2.5mm nozzle the same as Westone and UE900 so there are a plethora of choices. Two, the 3003 has the cable attached directly to the IEM. This precludes the use of either an aftermarket cable as well as the use of a balanced amplifier with a TRRS 2.5mm jack (AK240) or Kobbicon (ALO or RSA) termination.
This is only true if the standard tips don't fit. The standard tips fit most people including me.
