Noble Audio - the Wizard returns!
Jan 26, 2019 at 7:03 PM Post #29,221 of 36,096
My thoughts
The warranty doesnt cover damage caused by a 3rd party cable.
The Khan cable can be converted to a balanced cable by simply changing the trs jack.
Purchase a proper trs jack and diy the cable or take it to a cell phone repair shop and have them do it.
This way at least you know the pins will fit for sure.
He meant a balanced cable to connect his Noble Encores to the A&K Kann, not the Noble Khan.
What is up with the pins by the way. Are you saying an Effect Audio Cable will not fit like the Horus and Leo 2? Reviewers have tried both on the Noble Encore. Tks.
Jan 26, 2019 at 7:19 PM Post #29,222 of 36,096
There are hundreds of 3rd party cable manufacturers and thousands of pin manufacturers options out there. Not every one can perform under the tight tolerances required and frankly speaking not every cnc shop cares to in the first place.
So one ends up with pin sizes all over the map. We build our products to fit our cable, this we are confident about, other cable suppliers/sources we can not vouch for.
And on another topic
A great cover
Noble Audio Stay updated on Noble Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/NobleAudio https://www.twitter.com/noblebywizard https://www.instagram.com/nobleaudio https://nobleaudio.com/en/ contact@nobleaudio.com
Jan 27, 2019 at 3:25 AM Post #29,223 of 36,096
Blue Bundle (Blue SP1000m , Blue Noble Encore and Blue Note 75 collection) !
PS : Bundle selling in HK
Jan 27, 2019 at 4:35 AM Post #29,226 of 36,096
Jan 27, 2019 at 7:17 AM Post #29,227 of 36,096
i see you are a new member here so maybe have not done a lot of reading on the cable threads
worry not , Effect Audio cables are fine cables and i have not seen any complaints about them not fitting the Noble iems or any iem with the typical 0.78mm
only problem with a Horus or a Leo II cable would be the price , as they are quite expensive - but other than that no problems
Jan 27, 2019 at 8:31 AM Post #29,228 of 36,096
A great cover
Foy! Foy is the man.
Jan 27, 2019 at 12:31 PM Post #29,230 of 36,096
Thank you for the reply. Tks.
Jan 27, 2019 at 1:27 PM Post #29,231 of 36,096
I sort of posted about this a few weeks ago but didn't really ask a question. I listen for up to 8 hours a day using my Katanas and K10s at work. I love both of them. Am I missing anything by only using CIEMs vs getting a pair of high end closed back headphones? thoughts on the age old iem vs headphone debate?
Jan 27, 2019 at 1:46 PM Post #29,232 of 36,096
Missing anything, well that's hard to say, a great set of CIEM's can do just as well as full sized. I have heard full sized that I didn't care for as much as my K10's at the time. But I don't doubt if I tried enough I could find something I liked just as much or better. I have said this before when someone asked whats the best, the best is the one you like the most.
Jan 27, 2019 at 8:04 PM Post #29,233 of 36,096
If u listen to iems that much time a day, u should consider visiting your local audiologist and have them check you for impacted cerumen. (Ear wax)
Basically the tissue in the ear canal grows in an outward movement, moving much like a conveyor belt, slowly carrying wax out of the ear.
An iem inserted in the ear could disrupt that process. We (audiologist) see this a lot with hearing aid wearers and with people that use ear plugs to sleep at night or for hearing protection at work.
Jan 27, 2019 at 11:55 PM Post #29,235 of 36,096
The latest addition on IG with watch parts is sick, love the purple.
Thought you would like it! Just wait until the next one, it gets even better!
