- Jul 11, 2008
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
FA type E tips will change the signature, although all tips do to a greater or lesser extent. My experience with the E types is that they will tend to attenuate the sub bass slightly, and tighten up the bass signature. Also, they will bring the upper mids/lower treble a little more to the forefront. The beauty of tips is that they are the least expensive means of experimenting with signature changes to find what sounds good to you. BTW, the E's do seal pretty well for me and I too get a little "pop" when I remove them. Interestingly, FA iems I've tried have had nozzles wider than the FA E tip bore size. My 2 cents.Okay I have a question about ear tips and sorry if this had been discussed too many pages to skim. I think I've found the the best seal with final type E tips (props to who mentioned them) even tho they back out a bit from my ear drum and feel like they're getting loose, when I go to remove them I hear/feel a slight pop like there's a suction I'm assuming that's a prefect seal? Now my question is the K10u has such a wide bore, and the type E opening is probably half of of the K10 without a tip. Wouldn't that reduced diameter nozzle close out or somehow reduce the sound quality or quantity? Probably opening another can of worms here, sorry .....
Love Bangkok, hope you're going to get a Thai massage everyday. At about $9 an hour, it's a hard bargain to pass up, it's a daily ritual for me every time I go there.The gods smiled..... cabin door shut
And seats are empty
Back in Bankok and she awaits me
And seats are empty
Nothing wrong with a good burger, I don't discriminate against all American classicsHotdog giving a like of a picture of a hamburger.
But I identify as a human, so we're good hereHot dogs hate hamburgers because they are jealous that the burger is a sandwich. Where as the hot dog is pretending to be.
