If you attend the Singapore show, please come by and say hi
I will, John! Hope to see you and Brannan at the show.
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
I wouldn't worry too much about the output impedance of a DAP. In my experience with my K10s, anything I have used between less than 1 Ohm to around 3 Ohms is fine.
I just tried my K10s with a silver cable....and it definitely makes a difference in terms of airiness and soundstage.
I am interested in purchasing silver wires....but can anyone tell me what the difference between # of "cores" actually does and what that really accomplishes? There are way more cores than "pins" so what does an 8core silver wire really accomplish over a 4core silver wire other than the fact that it is.....thicker and provides back-up if one wire "fails"?
More cores is just about more "coolness factor" and cost. The amount of current flowing through these wires is miniscule. In my experience, different cables can affect the sound, but not make a night and day difference like you see in some posts. The Noble stock cables are already good quality and comfortable to wear (you can cut off the memory wire if it bothers you). If you want bling, though, knock yourself out with some custom cables.
A shame that a blind test would be difficult to arrange.thanks for the direct answer,
but i definitely wouldnt say silver wires are only "bling". I have tried my k10s with silver wires and they do make a difference which is why my initial post was not a "how much better are silver wires" but "whats the difference between core #". The difference is definitely not night and day as you said ... but the silver wires do change the audio in very noticeable (and better for my preferences) way which is why i will be purchasing my own silver wires to use.
Quite a palaver. If you were prepared to do it, the result would be very interesting.Not particularly i would think, just need a blindfold and someone (friend, SO, etc) to swap wires (or not) and put the ciems back in your ear and possibly hold the wires so u cant identify them by feel.
