NF Audio impression thread.
- Thread starter Dsnuts
Codename john
My issue with the Believe are they are not the most versatile of sets. Although I don't find them boring they are not a jack of all trades. I find you can morph the nm2+ to work with any musical genre. Do you find the mid peak troubling as others seem to? Doesn't bother me at all!There really is something special about the NM2+. They are very nuanced, with a delicate presentation. That’s not to say they you can’t rock out with them too, but I think they are very good with acoustic music and vocals.
IEMusic
Based on the graph, it should be making my ears bleed, yet I don’t find it bothersome in the slightest, even at loud volumes. I’m MUCH more sensitive to the 4KHz peak of the FDX1.My issue with the Believe are they are not the most versatile of sets. Although I don't find them boring they are not a jack of all trades. I find you can morph the nm2+ to work with any musical genre. Do you find the mid peak troubling as others seem to? Doesn't bother me at all!
alamnp
the only thing I don't like with NM2+ that I have to do tip rolling, which with $200 units should not...My issue with the Believe are they are not the most versatile of sets. Although I don't find them boring they are not a jack of all trades. I find you can morph the nm2+ to work with any musical genre. Do you find the mid peak troubling as others seem to? Doesn't bother me at all!
but they also can take EQ like a champ, just tone down 4k freq, you should be fine. I sold my NM2+ and kept Believe... since I actually listen to more acoustic heavy music. Vocals are better in NM2+, but like I said... I prefer my acoustic music better especially percussion and drums... Believe has insane precision on percussion.
Codename john
I love the Believe .. You're right percussion and timbre are spot on. Also they are very resolving and emotional. I'm in no way dissing them. They are both fantastic and a compliment to one another especially for the price. Will you get the tri 3 ?the only thing I don't like with NM2+ that I have to do tip rolling, which with $200 units should not...
alamnp
it may take awhile getting another $200 IEM after Believe. I really enjoyed Believe.I listened to alot of Coldplay, Believe can handle complicated music like a champ. The only thing it cause wear fatigue... after 3+ hours, not too “ear”nomics lol.I love the Believe .. You're right percussion and timbre are spot on. Also they are very resolving and emotional. I'm in no way dissing them. They are both fantastic and a compliment to one another especially for the price. Will you get the tri 3 ?
Next one, prolly LZ A7.
I also just got Tripowin TC01, which was surprisingly spot on, I would say, it is about 85-90% potential of NM2+, mostly due to tame 4K for 1/3 of the price.
bought it from Amazon, was going to return it initially. But then decided to keep it as NM2+ replacement.
slightly thinner vocal and more rounded sound stage, tamer 4k, not shouty, enough treble extension without being sibilance.
Hi folks! If I already have the NM2+, would you say it's worthwhile to get the OG NM2? Is it just 'the plus but worse' or is it different enough to have both?
Noob question: what is a crossover and how does one remove and install it? Is it as easy as switching tuning filters?Some graphs showing how some of the modular crossovers change the tuning on the NE4:
The NM2+ is a bit too hot for me, but using the AET08 is enough to tame it. It adds a bit of midbass boost though which I'm not sure how I feel about.My issue with the Believe are they are not the most versatile of sets. Although I don't find them boring they are not a jack of all trades. I find you can morph the nm2+ to work with any musical genre. Do you find the mid peak troubling as others seem to? Doesn't bother me at all!
The only thing keeping me from buying the Tc01 is the bass, some people say it's a very bassy pair. How would you compare the bass to the NM2+'s? Cheersit may take awhile getting another $200 IEM after Believe. I really enjoyed Believe.I listened to alot of Coldplay, Believe can handle complicated music like a champ. The only thing it cause wear fatigue... after 3+ hours, not too “ear”nomics lol.
https://en.wikipedia.org/wiki/Audio_crossover -- tl;dr a crossover is an electrical device that separates different sound frequencies.Noob question: what is a crossover and how does one remove and install it?
Example:
In NE4's case, you'll swap faceplates that contain different crossovers values/circuits.
Well, switching faceplates wouldn't be as fast as tuning filters but it still very easy.Is it as easy as switching tuning filters?
alamnp
well, you might like TC01, the bass is a step down from NM2+Hi folks! If I already have the NM2+, would you say it's worthwhile to get the OG NM2? Is it just 'the plus but worse' or is it different enough to have both?
I like this tips (w01) with my NA2, wide bore ,shallow fit https://m.aliexpress.com/item/10050...&terminal_id=7b5891377acf41e992b33cb99326ca87
Codename john
It's not bassy as such. It has a very exaggerated mid bass that may be off putting to someHi folks! If I already have the NM2+, would you say it's worthwhile to get the OG NM2? Is it just 'the plus but worse' or is it different enough to have both?
