Leo-
- Oct 20, 2007
Got a notification from the post tonight, and the AP200 is the only thing I'm waiting for at the moment. However I'll only find it out in two days since tomorrow is bank holiday...
Hello guys,
This post is dedicated to Hidizs AP200 owners.
Could you test if the AP200 hardware is recognized by the Neutron Music Player application for the Hi-Res decoding? The last version of Neutron should enable the Hi-Res 24bit decoding using the Generic Driver.
Thanks!
Neutron is an Android mobile application, in my opinion the best sound quality among the Google Play Store.
Pity.... As I've said couple of posts ago (if you read it) - latest FW 0.1.8beta excluded Google Play. I can only install apps now if I have .apk files. If Hidizs would not reply where did GAPS go - I would have to try to install GAPS myself.
If there is someone who wants to help the developer Dmitry and verify the compatibiliy of AP200 hardware, please download the following apk file:
http://neutronmp.com/download/dev/NeutronMP_NEON_DEV_191017.apk
These are the instructions you have to follow in order to get log files and send them to the developer:
You will need to create NeutronMP folder in the root of internal storage (where you see Android, Music, ...) and logs inside NeutronMP (you will get /NeutronMP/logs) then Neutron will do logging (Neutron must be restarted completely to start logging) and /NeutronMP/logs will contain log files which would be interesting to check. Make sure Audio Hardware -> Generic Driver is switched on. Try playing for some 4-5 minutes to accumulate logs. Then reboot device and do not start Neutron, access /NeutronMP/logs and e-mail log files to
neutronmp@gmail.com
Thanks!
kalo86
Hello guys,
Thanks!
How to check whether it uses 24bit?
If you want to check if Neutron is reproducing your audio files in Hi-Res mode, you need to go to Settings, Audio Hardware, make sure that Generic Driver has been selected, click on Generic Driver and select Hi-Res Codec (direct PCM), just confirm the settings and then Exit.
Another important setting is to enable the Follow Source Frequency.
Apply these Audio Hardware settings and exit.
Choose a track based on 24bit (for example), play it and enter again in Settings, Audio Hardware, you should see the out bit in the upper side of the view (see image):
Nope, still says Bits 32 (out 16).
