RojasTKD
- Jan 14, 2009
can you install tidal and play in offline mode?
And Spotify offline too
It runs Andriod 5.1 (I believe it's 5.1), so it should have all the capabilities of an Android device.
Hello. @Dobrescu George and @Hawaiibadboy
If you have a chance/ time (not a big one if you don’t). Can you please test the speed of playing back files via the internal memory and then via the MicroSD card. Also, if you happen to have a 256GB card, would be good to see if the AP200 can see the full available space in it.
As a bonus, when connected to your PC/ Mac, can you please check that it/ if a) comes up as a USB 3 device and the speed of transfer. I only ask this because the RK3188 SoC being use only supports USB 2.0 and would like to know if it’s just a USB-C port only or are they using a third party seperate chip allowing full USB 3 speed/ compatibility. Maybe @Hidizs Hk can answer some of these questions?
Once again, these are just technical questions, and please only check them if you have the time only, as with 7 days to go, I think the more important stuff people are asking like SQ, digital filters, UI speed/ usability and third party (Google Play Store) steaming tests are probably more important first.
Cheers.
And Apple Music offline too...
Cheers.
Let's hope someone has both
I was somewhat interested in the 300 something smething from Pioneer because it has a cool design, but not XDP-100R because I'm not very confident about the design.
Out of curiosity, does anyone know if HibyMusic supports ReplayGain tags? Cheers.
@Dobrescu George Can you confirm if there is hiss while using Dunu Dk 3001 with AP200. Dunu 3001 hiss with both O2 amp and fiio x5 1st gen.
Spotify up and runnin with ease. PC related questions are not my thing. I think George can reply to that.
Of the DAP's in my possession this one is time critical so i will focus on it as the campaign approaches.
Copy speeds are not USB 3.0 speeds,
I don't see any setting for ReplayGain, but I've seen something really awesome, Hiby is supposed to support play through folders!
I thought that was a mandatory feature for a modern Android DAPI don't see any setting for ReplayGain, but I've seen something really awesome, Hiby is supposed to support play through folders!
