kalo86
@Dobrescu George: do you think that the Hidizs AP200 could compete with the FiiO X5 3rd gen?
Awesome, can’t wait to hear more once you have more of a play with it. So far your early impressions already seem quite high, which is good to hear.
I was totally sold on the Black one, but I don’t know, this Blue colour has a bit of 80’s charm to it. I’m a little torn now.
If you have a cheaper set of IEMs to test with, that would be handy. Also, if you get to a chance, can you please test line out into a stereo system too. Cheers.
Correction, $299 is their MSRP. Shouldn't use their discounted price as comparison mark.
hi, can you check if the 3.5mm is emitting any red lights? or maybe a function to change the output to spdif.
i have not seen a usb that output spdif.
thanks
It really depends on what you're looking for, each jas very very different advantages.
I'm looking for the best audio quality between FiiO X5 3rd gen and Hidizs AP200 using them with the single ended output.
In these days I'm going to evaluate the idea of FiiO X7 MK2 for the balanced output.
I hope you can answer now
I honestly think that they have different sonic signatures and some people will like one of them, while other people will like the other one. X5-3 is smooth and romantic while AP200 is vivid and energetic, if I tried to put it in a few simple words. Each will appeal to a different public, I for one like vivid and energetic / happy signatures a bit more than relaxed/smooth ones.
Not sure you've tried yet... But Do the Digital filters on the AP200 affect it's sound signature ?
No Problem ! I don't know exactly what they do either!Yes, I think they do, but even with RE-2000, I have a pretty hard time explaining how they change the sound. Maybe I don't know what to expect exactly so I'm focusing on the wrong parts of the sound while trying to explain what these do.
Appreciate your quick reply and initial thoughts on the sound signature !
Pete
any idea how ap200 would compare to Pioneer XDP-100R ? especially after output power limitation removal for pioneer with latest firmware. am only looking for any advise but only regarding sound quality / power , don't care about any fancy bounces
100r can be bought almost for the same price as ap200 so I really need an advise here please
cheers
Mayebe this quetion will be answered soon
And Spotify offline toocan you install tidal and play in offline mode?
