Dobrescu George
Reviewer: AudiophileHeaven
@Dobrescu George
Have you had a chance to listen to Cayin n5ii ? if yes how does ap200 compare to it?
cheers
I am waiting on N5ii actually, so until it arrives, I cannot speak about it
@Dobrescu George
cheers
yeah I read in in N5ii thread your post , thought it was already with you. So I will be waiting with you ))))))) very curious about that one
I like ap200 but not so much not to let it go in a very nearest future , so I need to start looking into my next dap options
Absolutely possible. Not using this device but on 4 Android devices I use both internal and external storage for Tidal offline. For the record, the files stored on the memory card str coded to the particular device they are downloaded to. Taking the memory card and placing in different device simply leaves you used up space on your card with nothing usable to show for itI'm no Tidal expert, but are you sure it is possible to store Tidal off-line to external memory? Have you been able to do this with other devices? This would make the content transferable to any device and I think there is a limit to how many devices you can use with Tidal. I might be completely wrong, just going off something I heard one time. It might be worth checking with Tidal customer support.
Thanks a lot for your download link. Now that was fast!I just downloaded the latest (well, they did change the link file) firmware and installed it, it seems to be working (version is now 0.2.1Beta).
Screen Off:
press volume once stop again stop again stop = volume up/down
press and hold volume button = folume up/down
press quickly button twice = skip/rewind
The rest, I'll need to monitor if the player is stable, if power is less drained in pure mode and if the system is indeed optimized
You can get it at their site or through this download link I made for Mega (Please don't abuse it, that's my personal online storage)
Thank you so much. AppreciatedI just downloaded the latest (well, they did change the link file) firmware and installed it, it seems to be working (version is now 0.2.1Beta).
Screen Off:
I think they give you 50GB free storage. I used their appSince that's just a free storage plan, there is a limit on it that I'm not sure of. Hopefully it doesn't conk out, but I'll try uploading to dropbox as another backup, though Philippine internet speed isn't the fastest nor is it unlimited.
Screen Off:
I had the same hiccups as you in last version. Not expecting much as Hidizs only mentioned :-Yes, 50gb storage, I was thinking along the lines of transfer limits (allowed amount of downloads)
In anycase, so far the firmware seems stable, the 'hicccups' i had before (a song would suddenly stop playing, player shows its playing but progress bar is stuck. Sometimes it would automatically unstuck, sometimes I'd need to skip. Sometimes when i plug a new earphone, it wont play unless I skip.) Still checking on the consumption of power on pure music mode.
1.Add adjust volume and switch song function when the screen sleep.
2.Improve the stability of hidizs music APP
3.Improve battery life under Pure Music mode
4.Optimize system operation
Going to play with it a few days & see if its better.
