Dobrescu George
Reviewer: AudiophileHeaven
How did you get to the recovery menu?
shut it down
Volume - pressed, then press power and keep both for 15 seconds.
Finally got around to testing the dac in mode and it works perfectly well (pull down menu, select internal to shift to dac in) even with an adapter from micro usb (what the stock cable terminates to) to type c. (yes, I have spotify on the ap200, I'm just testing the dac function)
I'm surprised extreme mode on spotify is 48khz 24 bit.
shut it down
It's not.
Thanks! Now I gotta figure out the screenshot
Apparently so, tested it on the stock player with a known bit rate, that screen doesn't change. Does that mean that's the maximum the ap200 can utilize from the input source?
I'm not 100% sure if it can take screenshots.
That's kinda sad, though I've tried the typical suspects (vol down + power, vol up + power, single press power + drop down screenshot) i suspect it's still vol down + power but the os is blocking/reserving it for volume control.
Don't forget that this is Adnroid OS - go to Play Store and you'd find plenty of screehshot apps there. Standard button methods don't work in AP200. But many apps do.
I'm having a problem with my unit. I'm hearing a very soft but high pitch beeping sound as well as some other interference/noise sounds when the volume is very low (or paused). I notice it more on a sensitive pair of in ear more. Anyone else notice this? Any advice on what I should do?
Same here with the device I have just recieved. 128GB recieved with last beta firmware 0.2.0. But it's curious. I had no problem with Custom Art Harmony 8.2, but soft beeping/statics, in the left channel principally, with Sennheiser PX100 I had in my desk at work. No such issue with closed Fostex made E-MU headphones.I have the exact same issue since day one V.0.8beta. I've tried two different IEM's and it does the same thing. Its also done it on every firmware i've installed, plus factory reset and still present I have emailed Hidizs the issue and ¯\_(ツ)_/¯ - Maybe worth emailing them too, if they even respond anymore.
Thank you for your thoughts. I have just recieved mine and I'm positively surprised with the sound quality. Have to listen to it more to get a precise view. But I hear a musical device with good extensions, a little warm but good resolution with my Harmony 8.2. I agree it's in another leaguue than xduoo XD-05 that I own too. I prefer it to my Cayin N5 too, from what I heard.I tested it with my A35, phone with pha-1a, xduoo xd-05, wm1a. Aside from the wm1a, it's a lot better than the rest that I have. The musical quality is engaging, more fun to listen to but at the same time it's not overly colored. Low/bass is good, clear, not basshead quality as bass is heard if the track isnt thumping, but when it does, you can feel it. Mids are clear, intimate but not crowded, a bit forward, the vocals are nice, strings can be heard being plucked, hammers hitting piano strings can be imagined (that clarity is minimal with the tennmak, but beautiful on the andro) highs are clear, a bit extended but not sparkly.
Overall I'm very satisfied with this sonically, so much i wont miss my wm1a when I'm out and about.
Both on my Brainwavz B400 and TFZ My Love IIwhat IEM did you use that had those noises ? I wonder if this could be related to the jack/cable used..
