- May 7, 2017
How did you get to the recovery menu?
I once got there accidentally but did not know what to do so I past it. I think you go to the options of NAN FLASH/ SD CARD/ Internal SD...
Turn off, then turn back on, and firmware upgrade prompt should appear.Not very sure all i did was clicking on the install and this happen
okay doing it now how do i start the installation?
okay ive been using the player for awhile, and listening from Spotify, for some song with light intro or acoustics on the left side i would hear some buzzy noise on and off anyone got it? sorry for spamming so much post XD
Discovered this last night, tried changing head phones but no joy, cannot hear it over a song but its there at the start.okay ive been using the player for awhile, and listening from Spotify, for some song with light intro or acoustics on the left side i would hear some buzzy noise on and off anyone got it? sorry for spamming so much post XD
okay done installing lets see if theTurn off, then turn back on, and firmware upgrade prompt should appear.
Oh, people... I am getting tired to write the same things again and again:
Thanks a lot, this makes me feel better as I thought my unit was defective.
So 2 key issues remain alive, no offline storage to mSD for third party files and no connectivity with Mojo.
And Hidizs not answering my mails and these posts.
I will be finishing selling this device if next firmware update doesn't fix at least Tidal Offline
I'm using JVC FX850. I can notice the noise on other headphones and earbuds such as the apple ones as well, just not as noticeable as with an IEM. The sound randomly switches between high pitch beeps and scratching sounds. It's not noticeable when music is playing normally, but during song transitions or when it's a quiet part of a song, I can hear it. If I pause/turn off the music player, the noise is there for a bit until what appears to be the power on the audio out turning off.
anyone know how to shuffle all? on pure mode~
