NEW - Campfire Comet and Atlas
post-15007380
Post #2,821 of 3,287
Lookout57
What tips are you using? Remember the Atlas is a DD and if the seal is too good or you hear a clicking when inserting them it's not able to vent properly.
post-15007649
Post #2,822 of 3,287
dakchi
I'm using the Final tips that come with the Atlas. I don't think it has anything to do with tips. Tips will not block the sound. It is a bad connection in MMC connection. I don't understand why such huge defect can pass QC of such expensive IEM
post-15007670
Post #2,823 of 3,287
bvng3540
AKA bvng2210, dragon430
Washington State
Washington State
You are very wrong about the connection, it has nothing to do with the mmcx connectors whenever you used silicone tips with dd this issues will accur on ALL DD
post-15007691
Post #2,824 of 3,287
Matty Allen
Brighton UK and Pokhara Nepal
Forgive my ignorence but:
1 - Why would CA supply tips that do this?
2 - If as you say this will happen to All DD"s then why hasn't everyone else on this thread had the same problem?
A few people now have had sound stop working from 1 side. My memorial sale open box purchace is waiting at my brothers house for me until I get back in September. My 90 day warenty will have expired before I can test and try them.
Am worried.
post-15007753
Post #2,825 of 3,287
bvng3540
Washington State
Washington State
Am worried.
You still can used the silicone tips, just do not get too good of the seal like lookout57 said, The clicking sound is driver flex, but if you use foam tips all those issues are gone, but you lose some of the bass
post-15007834
Post #2,827 of 3,287
dakchi
I changed to foam tips and I confirm that I am not facing this issue again. It is insame how silicone tips can drop off completely the sound from the IEM. I was sure that it was a problem of connection. I am questioning why CA included tips that are causing this issue. I am sure a lot of customers will not think that the tips are the cause of this issue
Reactions: Matty Allen
post-15007946
Post #2,828 of 3,287
Caruryn
Greece
Greece
A reviewer said that Atlas works best with E-Pro graphene eartips and Acoustune AET07,so might wanna give these a try.
post-15007983
Post #2,829 of 3,287
mattiav
Xposting my rig pic from another thread to shamelessly plug adv custom tips - they're amazing
Nice! If the tracking info is right I’ve got my ADV custom tips for my Andro S sitting at the post office. If they fit well I may be ordering another set for the Atlas.
The one downside I’ve found with the Atlas while cycling is the wind noise is pretty annoying - probably due to the (tiny) vent. My Andros are much better in that regard. But both are really quite comfy, including over the ear wear.
Reactions: Luhar
post-15008062
Post #2,830 of 3,287
mashuto
The tips work fine, but there are just certain situations where you can end up with that effect. Its just a matter of sometimes getting too good of a seal, and isn't just limited to those tips.
It's also been discussed quite a bit in here as well, so hopefully a lot should have been aware of it.
post-15008121
Post #2,831 of 3,287
abirdie4me
When you get them, definitely listen with normal tips first and then the customs, you'll see what the fuss is about :wink:
Luhar, any issues with driver flex with the custom tips?
post-15008146
Post #2,832 of 3,287
Luhar
Usa
Usa
Absolutely none, they will feel a bit 'stiff' at first but when they are broken into the shape of your ear after a few wears they will feel like you're not even wearing them. Although you might feel this way from the get go! Just speaking from my experience.
Also wash them! After every couple uses, warm water and a tiny bit of hand soap rubbing gently.
Reactions: abirdie4me
post-15008150
Post #2,833 of 3,287
Luhar
Usa
Usa
Post some snaps of the tips on the Andros please :) when you get them
post-15008556
Post #2,835 of 3,287
abirdie4me
B-Stock Atlas just arrived. Initial impressions after an hour:
  • No issues with driver flex so far, although first thing I did is put spiral dots on
  • Sound great already, not sure if there is burn-in with these that will make it even better. Running from a Fiio M11.
  • B-stock didn't include anything other than Atlas, cable, and 1 pair of tips. Not an issue for me, I've got a lots of tips laying around and have a 4.4 balanced all-silver cable on the way
  • Included cable is tiny! I was expecting something similar to what came with my Polaris, but this one is super thin and light-weight. Sounds good though, so I'm not complaining.
  • Compared to my Fiio FH7 (also new), these clearly have much more bass. The FH7 are much smoother sounding overall and the vocals are a bit more forward, while still providing excellent details. The Atlas has more punch and sounds more 'fun'. I think they are a great compliment to each other, the FH7 for relaxing and the Atlas for rocking out or more critical listening
  • Value - I paid about $350 more for the Atlas than I did for the FH7. I think they are both worth the price of admission. If I could only have one of them, I'd probably go with the FH7 since I have a nice desktop setup for when I want to listen critically. My main portable use is around bedtime when I'm trying to wind down for the day, and the FH7 are perfect for that.
  • I have custom eartips ordered from ADV for the Atlas, hopefully that will help some with comfort. I can't imagine any improvements in sound, but I guess I'll find out soon.
