NEW - Campfire Comet and Atlas
post-15000967
Post #2,806 of 3,287
Tristy
England
England
How would you compare Comply foam tips to CA’s marshmallows?
The Marshmallows fit me very well, so I’m wondering if I could use them for other IEMs when people are calling for Comply.
Comply's are more comfortable as they react better to your body heat and they are slightly larger in comparison to the marshmallow counterpart. The isolation comply are more porous than the marshmallows though and the ends of the tips have some air holes which I find takes away a little of the sharpness of the treble / vocals. I think I prefer them over the marshmallows purely from a comfort and fit standpoint.
Reactions: Wheel Hoss
post-15001145
Post #2,807 of 3,287
Jearly410
San Antonio TX
San Antonio TX
I’m using crystalline audio tips exclusively.
post-15001253
Post #2,809 of 3,287
journeyman63
Oregon, USA
Oregon, USA
Looking for some advice or any similar experiences. I bought a pair of the open-box CA Atlas IEMs during the Memorial Day sale. They worked great up until yesterday, when the sound volume dropped off sharply in one earpiece. I thought it might be a blocked vent or debris in the grill, but there was nothing obvious. I switched the cable around and the problem followed the earpiece, ruling out a cable or source issue.
Is there anything I can attempt to do to fix the problem? I have an email in to ALO/CA but haven't heard anything back yet. I know they stand behind their products, so I'm hopeful they'll be able to help out.
post-15005122
Post #2,810 of 3,287
Patzig
Fort Worth TX
Fort Worth TX
I'm looking to buy a set of B-stock or lightly used (low hours and good condition) Atlas. I only see the Atlas for sale new for $1299 and a few sets on ebay.
Any ideas or anyone looking to sell?
post-15005225
Post #2,811 of 3,287
Luhar
Usa
Usa
Just curious - did CA help you out with this in the end?
post-15005248
Post #2,812 of 3,287
journeyman63
Oregon, USA
Oregon, USA
I emailed a couple times and hadn't heard back, so I gave them a call yesterday. I told them what was going on and they sent me a return label, saying they'd take a look and either fix or replace the earpiece. They also followed up on the emails soon after.
So the Atlas is in the mail as of this morning. I'll report back what the outcome is. I'm suffering a bit of withdrawal after having enjoyed listening to them for a few weeks. Looking forward to having them back and in full working condition.
post-15005257
Post #2,813 of 3,287
journeyman63
Oregon, USA
Oregon, USA
post-15005321
Post #2,814 of 3,287
Luhar
Usa
Usa
that's not bad since you'll end up sorted either way :) hang tight
post-15005347
Post #2,815 of 3,287
abirdie4me
Just pulled the trigger on the Atlas B-Stock, can't wait to join the club! I also just ordered custom ear tips for it from ADV-Sound, a bit risky since I haven't even heard the Atlas yet...but what the heck, you only live once.
Reactions: Luhar
post-15005451
Post #2,816 of 3,287
Luhar
Usa
Usa
When you get them, definitely listen with normal tips first and then the customs, you'll see what the fuss is about :wink:
Reactions: abirdie4me
post-15005457
Post #2,817 of 3,287
abirdie4me
It will be about 3 weeks before I get the customs, but the Atlas should be here this week. That should give me plenty of time to tip roll and develop a good baseline for comparison.
post-15005560
Post #2,818 of 3,287
Matty Allen
Brighton UK and Pokhara Nepal
Please let us know what you think of the custom ADV tips?
I am thinking of ordering some.
Trying to decide between ADV in America which look like a full sleeve or Custom ART in Poland which look smaller and like just the tip? Or ADV Iin the U.K..
Location does not matter to me as I'm traveling.
Apart price difference, can anyone compare these three custom tips?
post-15005668
Post #2,819 of 3,287
Lookout57
Trying to decide between ADV which look like a full sleeve or Custom ART which look smaller and like just the tip?
Apart from the price difference, can anyone compare these two custom tips?
The ADV aren't full sleeves, more like a half sleeve. One advantage they have that I love is you can remove the IEM from the tip while keeping the tip in your ear. This makes it great on a plane, you can take the IEM out to talk to someone and then put the IEM back into the tip in your ear.
Reactions: Matty Allen
post-15007275
Post #2,820 of 3,287
dakchi
Hi,
I just received my Atlas from Amazon and I already have a serious problem with it: there is no sound out of the earphones randomly. It seems that the MMC connection between the cable and earphones is not good. I have to play with the connection to have a sound back. Anyone facing this issue? any solution to this issue?
Thanks
