I've spent the last few weeks testing to see if the Sparkos SS2590's are an upgrade in the Conductor 3 Reference (C3R). So this entire post will be about my opinions on how the SS2590's compare to other op amps. This will be a bit long winded but to those that actually care about the specifics of how the SS2590 sounds then all information may be useful to you. To those that just want to know the outcome of the testing, here is my recommended setup in the Conductor 3 Reference:
*Singles (LP stage) = Sparkos SS2590 (35mm Burson Extension Leads Required)
*Duals (I/V stage) = Sonic Imagery Labs 994Enh
*Edited as my recommendation has changed. See a few posts down.
C3R Digital Filter = LP FAST
The digital filter is important. I typically use AP Fast but going to LP Fast was critical to getting the right sound with this op amp combo. How I came to this conclusion is below for those that are interested.
Background:
Up to this point I've tried close to 60 different op amps, and for the last year or so I've been using the SIL 992Enh & 994ENh's in the Conductor 3 Reference. The 992/994's offer a crystal clear sound with a surround speaker like sound stage. In previous testing I found the 992/994's were a a few technical levels above the next best discretes. I was quite happy using the 992/994's, but a few weeks back I was listening to a lower quality amp and was enjoying some bass heavy music. In that time I started to wonder why my C3R didn't put out the same quality & quantity of bass as a less refined amp, and that put me down the rabbit hole again of trying op amps to get more out of the C3R.
First I tried all of the other great discretes in combination with a 992 or 994: V6 Vivid, V6 Classic, Sparkos 3601/3602, and Staccatos. Some of the op amps like the V6 Vivid gave me that added richness & bass I was looking for, but all were such a significant drop in detail and sound stage that the overall sound was a downgrade to the 992+994 setup. In looking around about the only other op amp I could find that may be able to compete with the 992+994's is the Sparkos SS2590's. I decided to start with the Single 2590's to see how they were, and then when I heard the singles I immediately got the dual 2590's to try as well. Here's the testing starting with my original setup:
Op Amp Testing:
Sonic Imagery Labs 992Enh (Single) and 994Enh (Dual)
Sounds like a 5 speaker surround setup minus the subwoofer. Exceptionally clear and detailed, but also on a bit on the thin side. Lacks fullness and deep bass. Performs Technically better than every other op amp I've tried except for the SS2590's (more on that below..). In the pursuit of more bass & fullness, more op amp testing was needed.
Sparkos SS2590 (Single) and SIL 994's (Dual)
The surround speaker like sound stage of the 992/994's is gone (boo..), but the sound stage is still correct. It's just more stereo now instead of surround. Detail is significantly improved, textures are improved, the sound is fuller, bass is improved in both quantity and quality. Overall the sound is improved in a noticeable and impactful way. It's obvious that the Sparkos SS2590 performs better technically than the 992/994's. Hearing how much of an improvement there is, I immediately got the Dual SS2590's as I expected to get another big jump in sound quality by going full Sparkos. As is, this setup sounds excellent though.
Sparkos SS2590 (Single) and SS2590 (Dual)
I had some trouble installing the duals here. I tried using right angle dip8 adapters to install the duals flat in a "bull horn" setup and I was successful, but the adapters had a major impact on the sound quality. In the end I used Burson 35mm extensions to install the duals sideways by carefully bending the extensions using soft tip tweezers. As for the sound, going Sparkos was indeed another big jump in detail, richness, texture, and in the width of the sound stage. Sounds didn't have any hint of compression in them, they just extend as far as they are supposed to. Violins, piano, and other instruments sound more life-like than ever. Bass, specifically the sub-bass, hits harder and cleaner than any other amp I've ever tried. Very very satisfying. I immediately thought that this was the optimal setup in the C3R, however over the course of a week I started to notice I wasn't enjoying listening to TV, Games, or Music as much as my previous setup. In the end I concluded there's 3 problems with going full Sparkos:
1) The overall tone is lower than neutral. Voices sound deeper and lower than they should, not just by a little bit either.
2) While the sound stage extends well horizontally, it lacks depth compared to the 992/994's. This makes the sound 'flatter' than you would expect.
3) Treble is lacking. Without enough treble to make a a contrast between the lows & highs, there's less sound engagement even when there's more detail and richness. Or in other words, the sound is boring :/
Given how rich and detailed these op amps are, I tried to make this setup work. Silver headphone cables, rhodium extension cables, different filters. Nothing worked to correct the tone. As great as this setup is technically, it's just not right. So, more op amp rolling was needed to somehow get the detail, bass, fullness, and stage width of the SS2590's, but with a more neutral tone and more treble.
At this point I tested around 15 different combinations of Sparkos SS2590's and other op amps in various configurations. Important to note with all op amp testing is that the sound stage largely comes from the DUAL (I/V) stage, whereas the overall tone and the general sound comes from the SINGLE op amps (LP stage). There's a little give and take across all areas though. In testing I concluded that the only way to get a very high quality sound was to use a combination of the SS2590's and the SIL 992/994's. I did also quite enjoy using the V6 Vivid singles with the Sparkos SS2590 duals, but compared to having a 992/994 in the mix the detail loss was too great. So really the only options were to use the SIL 992+SS2590's or SS2590+994's. Back to testing...
SIL 992 (Singles) and Sparkos SS2590 (Duals)
This takes most of the sound stage of the Sparkos with the overall tone of the SIL 992's. So you get a full wide sound and great detail. This is a clear improvement over the 992+994 setup, basically sounding mostly the same with an extended sound stage and additional detail. The only downside is that since most of the sound comes from the 992's the sound still lacks some fullness, and can be perceived as a bit thin. Depending on your preference and headphones this may be the ideal sound setup for you, but it lacks the fullness I'm looking for in my setup.
Sparkos SS2590 (Singles) and SIL 994 (Duals) ... again
Back to just about where we started. Without the SS2590's in the dual slots the sound stage width is reduced a bit, but goes out further in depth. You end up with a kind of sound bubble that you know could extend further if only the SS2590's were in the dual slots, but it's still satisfying. The overall tone is completely neutral, with the fullness & bass being as they should thanks to the SS2590's in the single slots. This is also a clear improvement over the 992+994 setup. The only thing I missed was the extra richness of the full Sparkos setup, and so after trying several more op amp combinations I came back to this one and ended up playing with the digital filters. Going from AP Fast to LP fast did the trick. There was a shift which gave most of the rich detail of the full Sparkos setup and made the entire sound more robust.
So in conclusion theSS2590+994's is the clear winner to me. (Edited, see a few posts below for a better recommendation..)
If anyone finds any other op amps that can potentially compete with the SIL 992/994 or Sparkos SS2590's in the future, let me know.
Background:
Op Amp Testing:
