EternalChampion
- Aug 9, 2015
I could use some advice. I was trying the extensions with the opamps you've pictured. I thought I had all four in properly but when I powered on the amp it started smoking. Powered it off and took out those opamps and put the 4 Vivids back in. It plays music but has a loud hum. Burson wrote that they can ship me a new motherboard (not on warranty) but I have no clue about can I swap those out. He wrote that it is simply removing screws and reinstalling the new board. Does the whole inside of the unit come out in one piece and then drop in and screw in the new board then reinstall the opamps? Am I missing something? I hate to invest half of what I paid for the unit for a new motherboard and then screw it up. Thanks.
Sorry to hear that. Are you sure you placed the SIL op-amps in the correct orientation? V6 provide reverse voltage protection, but the SIL I don't think they do.
Also, did you bend the pins of the extensions a bit for a good grip inside the sockets? Loose pins is a major issue.
In regards to the PCBs inside I have no clue neither as I didn't have to unscrew anything yet. If you aren't sure about something just ask them and follow their instructions.
