RP2X
- Sep 26, 2005
Hi ive had my AT A900s now for almost 10 years, there great cans but the end wire is loose and sometimes gotta bend/twist the end to get both sides left and right working again, also one of the sides of the pads has worn out and I dont fancy replacing the pads since they cost about £50-60 and ive done it 3x already.
Any better closed headphones out there, perhaps with ones where the pads are easy + cheap to replace, any suggestions is appreciated thx.
