davidvanderbilt
- Mar 25, 2010
You've tried all of those headphones? So you are looking for a detailed headphone with some nice boosted bass right? Since you already have a nice amp, something like the higher end Denons or the higher end Ultrasones seems like somethings you would want to research a little.
Sure, thanks for the tip. I was just afraid that since i have the denon 1001's and don't like their sound signature (i think the highs are too harsh), then i might not like the Denon 2000's or 5000's. I will look into it though as well as the ultrasones. I have been very adamant about using the frequency response chart on headroom to find the sound signature i want, but I don't feel like it is always accurate
What are you listening too, in other words what's your source?
I use FLAC files in Foobar ( with Asio) with the iBasso D4 mamba amp which i use as both my DAC and AMP.
I found the 940 to have a even brighter sound then my SR80i's
Were the highs too bright? As in harsh?
I'm not trying to spark a debate, but with going through so many headphones so fast, did you give any of them a real chance to burn it/your mind to get used to them? How long did you spend with each headphone?
Sure, well I guess i exaggerated a little bit, it wasn't exactly a week, it has been two now, and i burned each headphone in for about 100 or so hours before i made my final decisions, and after comparing them. But i agree, i probably should have spent more time with each one. I feel like i spent a day or so with each.
If you don't have a preference of open/closed = Go Open
$500 is a great price. Let's try to get you a amp/DAC too!
Harsh sounds as if you're experiencing a evolution to basshead. What you might call harsh is the highs (treble) that are a little too far up there.
Gwarmi said Acceseroannahgoeoes, which are Grados that are tweaked: my favorite cans for anything.
Alessadros are what I find too tweaked and the personality of Grado are worked out.
The earlier Grado are more harsh but funner. Like SR60/80/125
Get a Grado SR325i - which are less harsh because the bass is moved up. Don't do the 225i with woodies idea that's been floating around. If you're buying a good headphone, don't mod it.
Then pick up a 1/4 to 3.55mm Grado adapter here
Well worth it to go portable
I don't expect you to have a decent source, so pick up a Clip+ (any size)
And look at some Ibasso portable amps. The Ibasso D2 is good with anything and Grado don't need a amp, but they do get better with one.
I've tried the SR 225i's and didn't really care for them. They were just too thin sounding to me. Maybe I didn't give them enough time to break in. I'll have to research if the 325i's have more bass. I am currently using a D4 mamba as my AMP/DAC combo.
