PanamaRed
- Apr 16, 2011
Grado 325 or lcd2
Grado 325 or lcd2
How is it possible that Grado Prestige SR 325i is at the same level as D7000 or T1 but twice cheaper?
If that Grado headphones are really comparable to the others, I will definitely buy them and some nice amp too!
Well, sounds logical...
Looks like the T1s should be the ones...
Well, it is not possible for me to hear them... And i don't undestand you very well - why all these people are trying to help me and this forum itself exist? If it's so easy and everyone can just walk out of his/her house and try everything himself/herself...
And I can hardly believe that headphones which cost so much money and are appreciated by many people (also by some on this topic) could be disappointing...
I am planning to buy an amplifier... but not sure if immediately with the headphones or some weeks/months later.
I am still confused... not sure if D7000 / T1... you definitely think that D7000, some other people recommend T1 for its universality. And I know that the answer is not certain and just depends...
From your original options of D7000, T1, and HD800, the D7000 is the clear pick without an amplifier. The HD800 pretty much needs an amp, and the T1 ABSOLUTELY needs an amp.
If you're trying to determine which of the three is best for rock / metal when used with proper amplification, I'd throw the HD800 out of the running. The HD800 does some things incredibly well, but rock and especially metal really aren't its strong points. For me, it's a toss-up between the D7000 and the T1 for those genres. The D7000 is warm and musical, whereas the T1 is more neutral and faster / sharper.
I'll throw in a recommendation for the Alessandro MS-2 as well. These were fantastic with rock and metal, and sounded great without an amp. I haven't had a chance to demo the Grado SR325i, but the opinion seems to be that the MS-2 is a little bit better balanced, and with a bit less treble energy than the SR325i, which is often described as fatiguing. Oddly enough, I actually preferred the MS-2 to the much more expensive MS-Pro as well.
Well, finally I decided... I will buy these D7000.
Now, can anyone help me to find a suitable amplifier
Now, can anyone help me to find a suitable amplifier to get some more from them? I saw several topics about it but some of them are quite old etc.
The Schiit Asgard performs very well with Denon headphones and only costs $250.
Really, I'm sure that any low-noise, low-distortion solid state headphone amp with a low output impedance would work great with the D7000.
Hey Mhoe,
Define 'suitable amplifier' in terms of your budget. Like many things in head-fi, this will determine suitability and also how much you
can choose from.
$100? $200? $300+?
