zerocoolhifi
- Nov 25, 2012
Do you have recommendation where to buy the er-4s and price that I should expect? Thanks
I bought mine for $299 from etymotic directly. I couldn't find anywhere cheaper, and ety has a 30 day return garauntee.
I saw the ER4-P for $289 on amazon but I guess it's better to spend ten bucks more and get it directly from the manufacturer.
I am seeing ER-4S for 199 and then both the ER-4P and ER-4PT for 279 and 289 - any idea on the differences?
The P and PT version are pretty much the same as far as I know, the latter is a newer model, both have less impedance that the S model, the S is the better sounding (I haven't heard any though) but you can convert the P or PT into a S with an adapter.
Audeo PFE 112
Etymotic Research HF5
TDK BA200
Ultimate Ears UE700
Vsonic GR07
Could you make a comparison to the question i posed here? (not of course for the R-50).
That is between the BA200, HF5, UE700, Audeo 112. Thanks
http://www.head-fi.org/t/658843/rock-it-sounds-r-50-review#post_9346869
The thing is that price consideration i can find Audeo 112 for 110$, UE700 for 92$, BA200 for 142$ and HF5 for 143$
One thing to know if i go with the pfe 112. or maybe two things
1) Isolation
Is it good? for traffic environment, walking, buses etc.?
That depends on what you're looking for. They are very good isolation with the foam tips, but not as good as the etymotic er4s. The silicon tips are average, which isn't a bad thing. If you want to block out all possible sound in a loud environment they are average. The er4s would give you a quieter listening environment. However, the pfe112 will block a decent amount of sound with the foam tips but still let you be aware of your surroundings, which can be nice in some cases. Overall, I'd call it average isolation.
2) No amp
I am not gonna use any amp
The pfe112 sounds excellent with absolutely no additional amp. Straight from my ipod it sounds extremely close to the quality from my c5 amp. Other headphones improve more with the amp, but the pfe112 are very efficient compared to the er4s for example and don't show "that" much improvement with the amp. However, I believe every earphone will improve with a good amp from something like an ipod. Not drastically, but always at least a small amount in terms of spaciality and apparent resolution of detail. But without an amp it's one of the best sounding and doesn't really need one.
3) filters
Do i need to buy filters?
a) That would be added cost and
b) Are they still being in production now that phonak is dead?
You don't need to buy filters. It comes with two grey and two black I believe (sets). From what I understand, the filters in the pfe are designed for sound modification and not as much as a sanitation filter. While I'm sure it does prevent things from getting into the set, and theoretically might get clogged at some point, I would say that's true of any filter out there. I can't guarantee this, but I don't see them needing to be replaced for a very long time if ever. And if they do you have one extra set of each color included. If you're worried you can buy them right now for cheap while they are made. You can probably even just clean them yourself. They don't appear to be as fragile as the er4s filters so they might be cleanable.
