Sound Eq
- Nov 9, 2013
can I assume Mad dog pro to be a nice basshead headphone compared to mad dog 3.2
Yesss. I can't wait to get minecan I assume Mad dog pro to be a nice basshead headphone compared to mad dog 3.2
I suggest listening to this song with your Mad Dogs if you got them. (and especially if you have the O2/ODAC combo) I do notice though, how revealing the Mad Dogs are now, you really need to have quality recordings to enjoy them.
M Ward - Undertaker
http://www.youtube.com/watch?v=sK4TiglUd5E
From what I've read, which is a lot, and based on my own MD 3.2, I can't imagine that any Mr. Speakers headphones would even remotely be considered basshead headphones. That said, I think the 3.2 sounds wonderful with many basshead music genres, and the Pro should only improve on this feature. Everything seems flat at the lowest frequency range, with no humps or emphasis in sub-bass or bass. "Bassheads" typically expect a bit of a boost in the lower frequencies...or an enormous boost.
I concur. The MD 3.2s are much more like Audeze headphones than they're like Sony XB series headphones, for example. I would even go so far as to say Denon D2Ks are more of a basshead can than the MD 3.2s. (I would go so far as to say this because I'm borrowing a pair of Denons at the moment and I'm doing a head-to-head comparison with my MDs as I write this.)
The MDs are totally competent with any and all bass-heavy genres but as sonitus says, they're not boosted in the bass at all. If anything...gun to my head...I find that the MDs are mid-heavy. And that's a huge stretch to say that.
It's just a 3.5mm semi right angled connector. The catch is that the jack is recessed so the cable terminal needs to be smaller than 8mm.I'm kind of a beginner to headphones, and have a question for you experts here. If I pick up a pair of Mad Dog Pro's, I'd like to swap out the cable for a longer one. I know I could use an extension cable, but I'd rather stick with one cable if possible. Could anyone tell me what type of cable I should look for? Does the connector that goes into the headphone have to be a specific type? I don't need anything crazy or expensive, just a cable with some flexibility and maybe 10-15' length.
Any suggestions would be much appreciated.
If you're looking for coiled: http://v-moda.com/coilpro-cable/Thanks a lot; that makes sense. Any suggestions on where I could find some cables that fit? I appreciate the help.
