MrSpeakers ETHER Flow and ETHER C Flow -- Inspired by Electrostatic Headphones
Nov 22, 2018 at 6:05 PM Post #5,342 of 5,796
in my experience, there was no change in volume.
Nov 23, 2018 at 8:28 AM Post #5,343 of 5,796
I've been using the EFO 1.1 without any tuning pads, slowly learning the differences between each one of the tuning pads. The white felt will definitely add that extra punch for you @Bambule.
I use my EFO 1.1 without tuning pads also. I'm not into the darker sounding HPs, and I really like the "padless" sound.
Nov 24, 2018 at 9:14 AM Post #5,344 of 5,796
today i got my new pad, for my efo.
it's more comfortable ( a lot more ), i don't know if the material is different but it look a little different and the dimension are bigger so the distance is more, the bass is more accurate in the sub bass region in my opinion, i can listen electro and edm without any damper and the result is better in the new pad, more impact and more quantity of sub-bass.
i had a lot of problem by the position of the headphone, but the new pad solve all :)
Very recommend
Nov 24, 2018 at 11:30 AM Post #5,345 of 5,796
Very recommend
Which new pads did you order? The flat or the angled pads? And how are they different from stock?
https://www.mrspeakers.com/shop/accessories/ear-pads.html
Nov 24, 2018 at 9:50 PM Post #5,347 of 5,796
Got mine a few hours ago. New pads on the left, old pads on the right:
New pad squeezed by an Audioquest Perch headphone stand:
Old pad squeezed by an Audioquest Perch headphone stand:
With the new pads, I don't need the black felt to have sufficient bass after the 1.1 upgrade, though it still seems slightly less bassy than before the upgrade. Felt pads + new pads sounds on par with the bass level before the upgrade, but takes away some of the exquisite clarity the upgrade brings. I'll be listening without the tuning options for now.
Thanks, Dan! :)
Nov 25, 2018 at 2:51 AM Post #5,353 of 5,796
That's were my serial number is in that notch between and below the 2 screws on the left side (left ear)
Same here, on both my Ether Flow and Ether C Flow. The serials match the certificate of authenticity as well. Thank you for the hint!
@kid vic Your picture shows the right side, not the left.
