The 1.1 upgrade was stupid silly to apply. Even with my meaty paws I didn't have any issues. Great job on that by the
@mrspeakers team.
I'm using Flow C 1.1 directly out of my Hugo 2. Like someone else mentioned in the thread, there is more room under the pads after removing the stock foam inserts. I had to adjust the sliders down slightly and the fit/comfort seems to actually have improved some.
Right away with the 1.1 upgrade you notice an increase in transparency and resolution. It's pretty significant and immediately drew me into the same tracks I just listened to several times. Everything also seems to be a tad more crisp and immediate. Also noticeably gone is the mid bass bump and slight warmness the Flow C had. This presents a more overall neutral sound profile, which reminds me more of the original Ether C tuning. I'm sure with the tuning pads, you'll be able to reintroduce the original Flow C profile, so it's really a win-win. Also the sub-bass seems to be relatively the same. Right now I'm going to listen some more with no tuning pads. Then I'll start swapping in some inserts and post my impressions later.
