I use only black foam most off the time but it is a no go for @lafeuill. So I love the capacity of changing on the fly.
MrSpeakers ETHER Flow and ETHER C Flow -- Inspired by Electrostatic Headphones
- Thread starter jude
Nick-s-f
Just got my ECF 1.1, applause to Dan and Co. These are tuned to perfection, haven't even used the 1.1 filters yet. Love them!
llcook51
- Apr 30, 2014
Absolutely beautiful! Steller looks and sound.Just got my ECF 1.1, applause to Dan and Co. These are tuned to perfection, haven't even used the 1.1 filters yet. Love them!![]()
Nick-s-f
Absolutely beautiful! Steller looks and sound.![]()
Cannot wait to try out the filters.
Does anyone in this thread find the filters to alter bass response?
I found my Ether C Flow 1.1 less full sounding after the upgrade, but the black felt rounds it out for me. Without it, I found the bass a bit lacking. I don't know whether the black felt increases bass or slightly lowers everything else, but I like the result. I look forward to trying again with new pads, which are supposed to bump the bass a bit.Cannot wait to try out the filters.
Yes, the tuning without any filters is a bit brighter than the original tuning, but with the damping you can adjust it to warmer. You can combine the filters, too. Personally I use white plus foam a lot, or just white.
From a damping perspective Foam<Black Felt<White Felt.
Make every day a fun day filled with music and friendship!
Stay updated on Dan Clark Audio at their sponsor profile on Head-Fi.
BuddhaBruce
Is that white felt and white foam?
Bambule
Previously known as Wozniak
- Apr 15, 2016
Improved pads in stock again?
Yes.
hemtmaker
- May 25, 2013
What’s the improvement?Improved pads in stock again?
Bambule
- Apr 15, 2016
The Memory FoamWhat’s the improvement?
kellte2
- Dec 21, 2004
I don’t want to be the guy, but since this is happening more and more on the thread recently, please use the search function.What’s the improvement?
(Spoiler: MrSpeakers changed the memory foam in the summer of 2017. This change to firmer foam improved comfort for some and also improved the low end response).
BuddhaBruce
I received 2 black foam inserts in my C FLow 1.1, is that normal? Is it meant to have 2 black foam inserts per cup after the pads are attached?
hemtmaker
- May 25, 2013
The Memory Foam
Thanks for the replies
Stu Paddasso
1 foam pad for each ear (or cup) can be used with ether or both felt pads. Also can be put in different order I like mind put in black form then white felt on topI received 2 black foam inserts in my C FLow 1.1, is that normal? Is it meant to have 2 black foam inserts per cup after the pads are attached?
Total: 10 (members: 0, guests: 10)
