sbradley02
- Aug 19, 2010
I own both Alpha Primes and C Flows. I've listened to both extensively with Schiit Asgard 2, Schiit Jotunheim, and Cavalli Liquid Carbon amps. With any of those amps, I find the C Flows more accurate, faster on transients, more balanced across the whole frequency range, and less fatiguing. You should check with MrSpeakers, what you describe should not be happening unless there's a defect or a bad mismatch between amp and headphones.
After a few hours listening, I am finding the same. I have no desire to reach for the black pads, which in and of itself is worth the cost of the upgrade. The low end is also considerably more authoritative.
