Subatomic
- Mar 24, 2005
I believe MrSpeakers lists pinouts for their cables. If you have any issues I can help walk you through the build when I get back to work on Monday. I will be building a balanced set as well as dual entry down to 1/4" for my own use. If you have not taken the Hirose connectors apart before that will be the first thing you will need to learn. I use long nose pliers and some tiny channel locks.
Yea, they're already built cables, so all i'll be doing is cutting off a length of cable from the hirose connector side and splicing them into the 3.5mm connector side (ie making a y split), shouldn't be too hard. I've attempted to make my own cable with the hirose connectors and they're a pain to solder since they're so small, luckily I won't have to do that this time!
