14christ
Well going from a schiit stack to a topping d30 pro a30 pro I'd say the variations scales very well.they have responded extremely well, basically like a whole new iem
Though I'm excited and eager to try out the new variations, I'm still having fun with B2 + Paw S1 combo.
The Paw S1 really make the B2 'sing'. I hear improved bass, mids and treble extension, as well as more clarity.
Can't help myself but to rant a bit here, is that the stock USB-C cable that comes with paw s1 is a HUGE disappointment. Within a couple week of use, even without walking with it in the pocket much, a slight pinch or twist can cut off the signal.
Ordered a right angle USB-C to lightning cable from Woo audio, feel really sturdy, but a bit stiff. Works great so far
Really happy with this combo so far. Ordered a new 4.4 balanced cable and waiting for it to arrive.![]()
Yea I've been looking for something like that, but I think this doesn't comes with lightning to usb-c options. What I'm using now with the elastic bands are just a temporary make shift solution....until I found a better one.I recommend this connector for a cleaner setup:
Thanks, I will check this out. The first one looks really good!https://www.amazon.com/Earphone-Upgrade-Improves-Replacement-Audiophile/dp/B08ZHVZY9N/ref=sr_1_3?dchild=1&keywords=kbear+24+core+cable&qid=1626137149&sr=8-3&th=1
This is the one I am using:
https://www.amazon.com/Detachable-Upgrade-Earphone-Replacement-Standard/dp/B07RZY5C8D/ref=sr_1_3?dchild=1&keywords=kbear+cable&qid=1626137258&sr=8-3&th=1
I think the TRN T3 is pure silver (the second one in the link is silver plated), but compared to actual KBear Limpid pure silver cables it falls short in material, assembling and build qualityThanks, I will check this out. The first one looks really good!
BTW, I bought TRN T3 last week from Aliexpress. This seems similar to the second one.
I wonder if the Variations is like the Monarch where you can increase the bass with impedance adapters. Might get to monstrous levels of sub-bass though.EQ is probably a better opini
Nah Final E type has small bore, the silicone material is good though. The E-type is bass booster or treble tamer.Welp, tip rolling the Dusk and using up filters before realizing I should just tip roll without filters til I figure out what to stick with lol.
Actually preferring the stock tips sound, but they are less comfortable. Xelastec sound decent, but just a bit off. Symbiio, Spiral Dot, Spinfits (never seal right for me) I didn't like either the fit or sound. I think anything with a wider bore kinda kills some of the soundstage, stuff far out to the sides loses some detail. Might pick up some Final Audio E tips they are similar in shape to the stock tips.
Tried Hiby 20ohm impedance adapter, yea it elevate whole bass floor, but not to the curve I want, I want a Aria like straight glide down slope, raising 100-200hz but keep sub100hz as-isI wonder if the Variations is like the Monarch where you can increase the bass with impedance adapters. Might get to monstrous levels of sub-bass though.EQ is probably a better option.
Which dac amp setup are you using?Tried Hiby 20ohm impedance adapter, yea it elevate whole bass floor, but not to the curve I want, I want a Aria like straight glide down slope, raising 100-200hz but keep sub100hz as-is
Monarch/Variations style sub-bass L shape bass is good for EDM/pops but I do miss fuller mid-bass for Rock/Baritone instruments, hope there is a switch to flip.
Do you mean lowpass filter? I use 4.4mm balanced with low-dispersion Lowpass Filter setting.Which dac amp setup are you using?
