wind016
- Jun 19, 2009
Make sure to EQ the bass all the way up to get that true Studio™ sound.
[size=12.0pt]Having more bass isn't necessarily a bad thing especially if you have sensitive ears. Try listening to an AKG K701 in the morning. It's painful. A headphone with strong bass presence won't hurt like that.[/size]
For me a true bass, is a bass that provide nice impact, slam, thump. I don't care if there's a ton of bass, if this doesn't translate in a kind of energy.
[size=12.0pt]Definitely, but having a bit of leeway in bass impact is nice. If a headphone can only provide accurate bass impact or less, it will get a bit boring for certain genres. Wouldn't you like a bit more once in awhile?[/size]
Depends on the 770 model. The 250/600 models are quite balanced (I preferred the 600 ohm version the best), but the 80ohm DT700 can bring the bass...no question and actually has more impact/control/depth than the Pros by a good margin....then throw in the large price difference and it's a no-brainer....the beyers win for closed bassy cans.
EDIT: Just saw that you picked up the Pros...please say you got the black ones and not the white at least.
[size=12.0pt]Nope, I got the white ones thinking they would match my more effeminate body [/size]
While the Pros are "decent" sounding, they go for $399. That's the issue. For $125 maybe, but for $200 (half the price of the Pros), you can do better and save $.
I believe it is definitely overpriced at $400. Though I have mixed feelings right now.
OK...
How should I say this now? I can not standing listening to the Beats Pros without EQ or for long periods. I've burned them in a few hours while I left the house and they started to open up. The bass started clearing out and I can hear more clearly. The 500-1K sibilance/distortion is still there and in addition to a painful 5K distortion. Also, the clamping is incredibly tight.
However, adjusting an equalizer like this
makes it fairly decent sounding. Warm and not very offending. Sounds good with these kind of jazz/hip-hop tracks as long as the EQ is running
or with Lady Gaga style pop music.
Vocals are pleasant and full as long as the 5K frequency is lowered. With an EQ, the headphone is not particularly offending. Without EQ, I'm not surprised people don't like them. There is much more distortion when music is playing than the graph would lead you to believe. If you do not EQ, the distortion is very apparent.
The headphone has plenty of midrange distortion, but EQing is fairly effective at hiding it. I suppose if you like a headphone which sounds like a better version of Sony XB700 and is OK with keeping the distortion hidden under EQ, you might like the Beats Pros. As for me, I'm getting irritated listening to them. EQing them doesn't make them sound bad, but they don't sound like $400. Maybe around $80 would be right as that is the amount of clarity I would expect from a $200 headphone with this amount of bass.
I'm not going to bother with a review. I'll be returning them.
