LasherV
Yes I am but I have control of the upstream signal with my Darkvoice.Are you using the direct drive (jumpers set to send the full 50 watts per channel to the headphone jack) mode to drive the M1060s?
Lasher
I am on the largest headband setting and it just barely fits.
I don't wear hats so I have no idea what my hat size is. I have my HD 6XX set to 9 clicks if that helps at all.Can I ask your hat size?
Surely there has to be others out there whose headphones smell like they just came off the assembly line and sprayed a few too many times with chemicals? I am on the other side of my bedroom and I can smell them and the case open.
Also sadly the right 2.5 mm jack on my cable is faulty and needs to be replaced. It keeps cutting out in certain positions so hopefully someone from Monoprice can ship me a replacement cable. I have been waiting to listen to this set of cans.
I'm also trying to determine if I have channel imbalance of it's just my ears as I think the right channel sounds a bit different from the left channel after returning home to these cans today.
edit: reversing stereo channels moves the voice so I suppose it's just that a majority of my songs have left-leaning voices?
Do you have a source that lets you output in MONO rather than stereo to check for imbalance?
Stereo to mono adapter ? ( hmm do they sell those )
I'm on the fence about spending money on a balanced cable. My headphone amp has a true balanced circuitry. I've seen recommendations to use its balanced output for best sound.
Will I hear a significant difference from the stock cable?
2.5mm to 4-pin xlr can be had inexpensively? Everything I've seen has been $70+.If you have a balanced amp, why not try it? 2.5mm balanced should be quite common, so you should be able to find one at a reasonable price. If there is any sound difference, it will be from your balanced than what a cable can provide.
From my Bryston, balanced and SE sounds different. Balanced sounds like ambient sounds are being lifted or perhaps the lower and upper treble frequencies compared to the mids. I like it with live recordings since ambient sounds provides the feel of environment/ambiance.
Here's one for little less.2.5mm to 4-pin xlr can be had inexpensively? Everything I've seen has been $70+.
Hmm ok, thanks.. None of the made to order sellers charge less than $70. or more.Here's one for little less.
https://www.amazon.com/Sukira-Hifim...19702139&sr=8-11&keywords=2.5mm+xlr+headphone
If it's too much, you can get one made.
