Here's Version 4 of the fazors:
100mm Mounting Ring
106mm Mounting Ring
V4 Fazor base
Modified to work with HiFiMAN mounting rings. There is a 100mm mounting ring that can be used to mount Brainwavz or similar pads if desired. Or you can use the standard 106mm ring to fit flush with stock or Audeze pads. Uses much less material than the previous version but not quite as sturdy. Can print an entire 100mm or 106mm set in one job with a Anet A8.
@PockyG thank you for your continuing work to upupdate and improve your fazor design!
Is there any sonic difference between v4 and previous? Or the grate part is still the same? And is this the “easier to print” version you mentioned in your last post?
