Brahmsian
Leather Honey it is, then! Cleaner and conditioner together.Leather honey...worked great.
M1060s...beats the hifiman 400i tosses them off a 20 story building and then body slams them just to be sure they are dead...the 1060s are an improvement over the 400is in every way
Actually, not in every way. If you mostly listen to classical music, I'd say go with the 400i over the M1060 (or buy both). I ended up with two headphones that perfectly complement each other for all my needs. Very happy with this combo.
So, does these still have something to offer if one already owns the HE400i, HE560, HD650, HD700, X2 and Q701?
opinions from people who actually own one or more other planars seems more reliable to me due to their wider experience...if I don't find them to be on the same level as the HE560 I really don't need them...The fact that I really really enjoy the HE560 makes me think that I'm crazy for even considering getting these as well.
so I jumped on the summer sale for the HE560's instead.
At the current price of $499 for the HE560, I think you made the right choice. If you only had the HE400i and the HD650, I'd definitely tell you to get the M1060, which on the one hand complements the HE400i and on the other is much more fun and enjoyable than the HD650 (IMO of course).
So with the vegans I did the paper towel mod over the foam and I didn't like it, it's hard for me to explain but it sounds less open
Yeah, I had the same experience. I decided that the pad swap was all I needed (I'm using the lambskins though).
+1 Sounds right to me that the HE560 complements the M1060 if you listen to classical music. If you have the M1060, then I think you'd do well to complement them with the HE560 for classical. That's assuming you have an amp that can drive the HE560 and further assuming that you don't listen to music using your phone or laptop. I say this because I saw that DavidA wrote that "if you are only using a laptop then I wouldn't recommend the HE560 only because I have been disappointed every time I tried the HE560 directly from a laptop or desktop system even if the system had a decent sound card like the STX." For that reason, I decided not to get an HE560 even at the current price.I actually think the 2 headphones can complement each other well. The M1060 is more of a "fun" headphone. It isn't super detailed or precise to me, and maybe a little loose in the bass, but it is absolutely a joy for high energy, bass emphasized music like hip hop, electronic, and modern pop. It also has a big soundstage with good instrument separation and air that gives it a really big sound. But I would probably prefer to listen to more natural instrument genres on the HE-560 for it's resolution and more neutral tonal balance.
Whether you should buy the M1060 if you already have the HE560 is another question. To me, it would seem like a downgrade, but then I haven't listened to the HE560.
