SonicTrance
Member of the Trade: Custom Amp Builder
I updated first post with final pics of version 2.
well done on an extremely good looking AMPI updated first post with final pics of version 2.
Thanks!well done on an extremely good looking AMP
I am glad to hear it sounds good
Thanks!That's a beautiful amp, inside and outside!
I can't tell you if they work or not as my tubes are not microphonic. I think they look cool, that's why I got them!Do those dampers work? Do you have bad microphonics without them?
But then it would be in thw signal path, right?That's how I see output transformers, an old flawed methodology . As I mentioned in the other thread, a voltage follower buffer by definition will skew the current through the transformer due to its inductance, I think if you are going to stick with a transformer output then driving it with an active current source buffer instead would perform better because it will ignore all parasitics thanks to Kirchhoff , after all a transformer is run by current, not voltage.
I would not have believed this if I didnt witness this myself on my mini amp.Using the topology described in this thread you can achieve top results using only a cheap OT...
Hey SonicT, what was your reasoning on the 47 tube?featuring 6C8G input and 47 output
Problem is that they all still cannot convey as much 3 dimensiomal space as good as a tube amp..
So the amps with poor soundstage are revieled with headphones...
and so I can also see how MrCurwen states the use of paralleded tubes can blur the details.
So now with the positive experience of this mini amp I am very convinced in these New approaches, instead of older & expensive designs.
I see there is also the 46 tube and the 71A tube and the 6A4 tube,
All being like the 47 as a lesser cost alternative.
I need to look further into the output tube choice,
as I was heavily under the impression that the 45 and 2a3 was best and the 300b most linear..
But would still would like to implement some change like an autoformer for volume, if not too expensive.
Anyways, I would like anyone's input on the DHT output tube choices..
It was recommended to me by MrCurwen as he knows I like big bottles. I just wanted to build this amp using DH tubes and wanted to use globe tubes as I like the look.Hey SonicT, what was your reasoning on the 47 tube?
The 6C8G was chosen for two reasons;I know you have very similar taste as me in tubes and I also love the 6C8G as driver tube, but that was in our LittleDot amps which (like most tube amps) is prone to tube rolling differences to get best sound...
You can use any linear tubes you want and it'll sound fantastic! If you build with the output buffer you can also use output tubes with high rp, if not then preferably use output tubes with low rp. Remember, if you look at datasheets for a pentode it will list a very high rp. You need to look for the triode curves for that tube!Anyways, I would like anyone's input on the DHT output tube choices..
Not really, no.Sonic do you have a comment for this?
This^^Again, 4P1L is the undeniable king of DH tubes. And also king of all tubes in it's mu and rp area. Only reasons to use american tubes are
1) aesthetics
2) you are building a recreation of a classic amp, i.e. aesthetics.
Not to say you can have first class results with them also; the 47 was after all ranked almost as low THD in the distortion benchmark I linked way back.
Yeah sorry thats just my own opinion of some equipment that use tube for the sake of having it,As an aside, I have never heard the term "fake hybrid" before. Please elaborate
Yes my mistake I really need to do more research into these tubes .71A as a LESSER cost alternative to the 47?
That's some real advice! much appreciated thanks.) If you have a specific aesthetic in mind, go for 33 or such. 47 if you simply must have big bottles. 2A3 is for suckers, 45 is too expensive and 300B is just pointless (although very pretty and linear).
Aesthetics is very important to me. So is SQ of course. I want the best of the two! I'm very happy with my choice of tubes. Though, the DH tubes each require a separate PT (winding) and their own reg. So it dramatically complicates the build! That being said, I have no regrets!
Yes, they are good choices!The more I looking at your tube choices,
the more I see myself liking your choices.
Yes, separate psu chassis seems to work very well!In really like the implementation of your
Chassis setup
I in same boat I have to check my socket pins for a cold solder joint that opens with tube heat 2min into playing music .I just had part of the trace come up during a repair but managed to circumvent that. I'm still trying to fix my LD!!!
Thanks, baron!Wonderful work Sonic!
