moosefet
- Dec 20, 2016
I just signed up to post my build but I am not allowed to post pictures yet
Here's a summary I wrote up on another forum:
Hi,
I have a quick question regarding the 17EW8 version of this amp, I believe 'The equaizer' had discovered this tube as a replacement but back in 2010 couldn't find the spec sheet with the load lines.
Tried reading the 400+ pages but this is very confusing. The actual 17EW8 load line are now available on-line so I wonder if a schematic showing the optimal value has been created. Would someone with good tube knowledge be willing to find a nice linear bias region with not such a high gain as 50 ? Even a text with the right value found woud be really awesome.
Also, has someone come up with a good idea to reduce the very high gain of this tube amplifier ? The 17EW8 has a mu of 50. My other headphone amps have a overall gain via global feedback of 5.
Data sheet for 17EW8 including load line can be found here : http://tdsl.duncanamps.com/show.php?des=17EW8
The sound is really good but the excessif gain is ruining the whole experience. My pot has 20 clicks and past the 4th click it's already too loud...
For fun I have included a pic of the HA.
Thanks for your help.
Eric
Im wondering if they could work in a Starving Student build?
I've never built an Amp before, but I really fancy this so I'm going to give it a go. A quick question for the techier peeps out there. Earlier in the thread it was said the phono inputs could be replaced by a Jack if prefered. Would it then be possible to do away with it altogether and replace the jack/phono input with this or something like it
https://www.aliexpress.com/item/PCM2704-USB-DAC-to-S-PDIF-Sound-Card-Decoder-Board-3-5mm-Analog-Output-F-PC/32724517687.html?spm=2114.01010208.3.1.UxwpzV&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000074_10000032_119_10000025_10000029_430_10000028_10060_10000067_10062_10056_10055_10000062_10054_10059_10099_10000022_10000012_10103_10000015_10102_10096_10000018_10000019_10000056_10000059_10052_10053_10107_10050_10106_10051_10000053_10000007_10000050_10084_10083_10000047_10080_10082_10081_10110_10111_10112_10113_10114_10115_10000041_10000044_10078_10079_10000038_429_10073_10000035_10121,searchweb201603_2,afswitch_2,single_sort_3_price_asc&btsid=6922bd54-b764-421e-92da-b398bd722123
by un-soldering the 3.5mm jack on the PCB and soldering wire straight of it and use that as my signal input? In essence I would thereby have created a USB valve headphone amp. Has this been done? I've tried searching but this thread is so big and so technical, its easy to get lost in.
