Juaquin
- Nov 20, 2008
No kidding - for those who are ordering kits, wait 'till you get the package. I'd almost go so far as to say that TomB is obsessive-compulsive the way he packs those things
Originally Posted by the_equalizer /img/forum/go_quote.gif Unfortunately I don't think such an adapter exists, even though I know there are adapters for some popular audio tubes (like this one, for example); so this 19J6 -> 12AU7 adapter would have to be custom built. |
Originally Posted by burgunder /img/forum/go_quote.gif I seem to remember an article about DIY tube adapters, but I'm not able to locate it rigth now. Edit. I found what I was looking for http://www.head-fi.org/forums/f5/rev...ifiers-301219/ |
Add a couple of regular ceramic 9-pin tube sockets and copper pipe caps.7 pin minature plug -fits sockets for 1L6, 6AU6 etc
good for making tube adapters and test jigs with
screw on back shell - NOS $7.00
Originally Posted by Juaquin /img/forum/go_quote.gif No kidding - for those who are ordering kits, wait 'till you get the package. I'd almost go so far as to say that TomB is obsessive-compulsive the way he packs those things |
Originally Posted by Juaquin /img/forum/go_quote.gif The "tweaks", besides doing obvious replacements (extremely high-end caps in place of the regular ones, etc) is to build one of the other Millet's, like the MiniMax. Similar topology (hybrid) with more bells and whistles. Tube rolling is not possible the standard way these are built. It is possible to use 12AU7 tubes, but it requires changing some resistors and a different socket, so it's not so much rolling as it is rebuilding. A couple posts up, Equalizer mentions some socket adapter information that would make switching back and forth easier, although I still wouldn't call it rolling. If you read two pages back, you'll see the kits will be going for $120 and they'll be available at Beezar Audio on Friday night. |
Originally Posted by Juaquin /img/forum/go_quote.gif Ah, so you can roll with a resistor change? Good to know. Still not quite plug-and-play, but with creativeness (a DPDT switch mounted to the case, as you suggested) you could make it pretty simple. |
Originally Posted by the_equalizer /img/forum/go_quote.gif I think I need to clarify what I wrote above As you very well mentioned in your previous post, a 12A_7 version differs from the 19J6 version in two ways: Electrically: you need to change R2 and R8 to be 390 Khoms Mechanically: you need to use 9-pin sockets for the tubes (as opposed to the 7-pin socket used by the 19J6) So once you change that socket, plugging in a 19J6 is no longer possible... (unless you use adapter sockets cheers! |
Originally Posted by loki993 /img/forum/go_quote.gif Is this a recommended setup? How do they sound compared to the 19J6. What little Ive been reading in the past few days, Haven't been on the site in a while, is seems that the 19J6s are getting hard to find. True? |
Originally Posted by the_equalizer /img/forum/go_quote.gif Yup 19J6 are currently scarce, though some recent posts mentioned they're available at some sites at $10 US per tube, which is still cheaper than new current production 12AU/X/T7 tubes. I wouldn't call it a 'recommended setup' It's just another option at your disposal to build the amp. The sound is slightly less warm than the 19J6, somewhat more edgy, but that's only my perception. If you search the thread for 12SR7 you'll find there's a third option using cheap and easy to find 12SR7 tubes. I haven't built or heard that version so I can't comment, but those who've built it like it. You can certainly build this amp for less than $50.00 but you'll obviously have to forego the kit. Get the PSU from e-bay, get the tubes from a tube supplier, be creative for the enclosure, etc.. Having said that, the Beezar.com kit is seriously worth it. An outstanding value in all respects: boutique output capacitors, 1% metal film resistors, WIMA film caps, a pre-drilled extruded aluminum enclosure... Having built one, I can say that the results are so professional looking that I could barely believe I had put the thing together myself. cheers! |
