Millett "Starving Student" hybrid amp
post-6340352
Post #4,516 of 7,240
the_equalizer
Originally Posted by revolink24 /img/forum/go_quote.gif
I've got a puzzle for everyone.
I said earlier that whenever I tapped one of my tubes, there was a very loud cracking sound coming out of the headphones. I swapped tubes, and lo and behold, the other side began cracking, so I ordered some new tubes. 5 of them, in fact. The problem is, that the problem occurs with ALL 5, and only one tube of the seven I now own seems to not do this. I doubt that all of them are bad, and can only hypothesize that the one is very good and there is another problem somewhere. Anyone have any idea what that might be?
Oh, and I'm using a pcb build.
Could be that that particular socket is defective, maybe one of the pins of that socket is very very loose.
It could also be a cold solder joint for one or more of that socket's pins.
cheers !
post-6340360
Post #4,517 of 7,240
revolink24
I've been suspecting that for a while, it's just odd that it would happen to both sockets and not affect one of the tubes. The pins must be bent oddly or something.
Anyhow, I guess I'll deal with what Ive got for now and worry about getting new sockets later. It just happened once without tapping it and I don't particularly want to damage my ears or headphones.
post-6340399
Post #4,518 of 7,240
tomb
Member of the Trade: Beezar.com
It's tough to tell for sure, but it could still be the tube pins. Vendors are dragging the bottom of the barrel for these tubes now and many of them are in very sorry shape when it comes to the pins. I've tested many of them that registered as bad, but then months later went back after wire-brushing the pins and they tested good. It's something you can try, but do it very carefully - then use some alcohol to clean up so there's no fine metal dust to further exacerbate this issue.
EDIT: Heck, I've had some that had so much corrosion on the pins that the pins wouldn't even fit in the socket holes - ugly, green, foul stuff, too.
post-6340432
Post #4,519 of 7,240
Logos
Originally Posted by tomb /img/forum/go_quote.gif
OK - the price for this round of kits will be $120.
As stated, the heat sinks continue to increase and the cases are slightly higher than before. Finally, even though the BOM shows $118, there are a couple of hidden costs for me:
1. The power caps are Panasonic FC's. Those are $2.65 each at DigiKey.
(Pricing is based on the Mouser column except for these.)
2. For this round of kits, I am drilling and gluing the tube sockets so that you can use the tube LED's without any additional work.
#2 is a significant added feature, but one many of you have requested.
Well, that is more than fair. I'm surprised you're actually justifying the low cost, and doing all this extra work for the kits. You've got a heart of gold man, a heart of gold.
...Now to get me one of these things...
post-6340534
Post #4,520 of 7,240
Llama16
Yeah tomb,
I can't stop envying your effort. That you are going to make the sockets yourself, wow!
It would be more then reasonable to raise the price just for that.
You're making many happy!
post-6342531
Post #4,521 of 7,240
Dunceiam
I hate to sidetrack the thread with such a meager question, but how else does one learn these things?
I'm doing a PtP SSMH, and looking over the schematic, something caught my eye - why are there resistors/capacitors connecting to ground? (ex. R6, R12, R5, C6, R11, C1 - too name a few). This is one of my first non-stick in hole and solder projects, so excuse me for the quick question.
post-6342669
Post #4,522 of 7,240
timmyGCSE
I won't have the money to order the PCB kit, I'll probably look at doing this in a month or so..but from what I read above it sounds like the tubes are in that short supply that I may not be able to?
I found a place selling the tubes for $4 a piece but haven't enquired about that yet
post-6342711
Post #4,523 of 7,240
tomb
When you do, I bet they tell you they don't have any. If a vendor does have some, they won't be $4 anymore.
Every electronics design has resistors and capacitors connecting to ground. You might refer to some of the many electronics articles and books that have been talked about often in the DIY section. The Search Tool is your friend.
post-6342913
Post #4,524 of 7,240
timmyGCSE
so I have no other option unless I can just be lucky and source some from somewhere?
post-6343090
Post #4,525 of 7,240
Llama16
I don't know if this is possible on the PCB, but equalizer has gone with the very accessible, cheap and new production 12AU7 guitar tubes.
Check the link for any help. It could be a very helpfull solution, and they don't sound bad either I've heard
If you've got any questions contact equalizer, who has showed me as well.
http://www.head-fi.org/forums/6024902-post3873.html
post-6343191
Post #4,526 of 7,240
revolink24
I promised pictures 8 million years ago on this thread, so I've finally made one.
And about that $120 price on those kits, I can't think of anything but the amazing amount of effort you put into this stuff for such little reward. The care with which you treat every order and customer is amazing. Thanks for all your hard work.
post-6343276
Post #4,527 of 7,240
the_equalizer
Well, if you manage to get an adapter tube socket, then it would be easy to use the 12AU7 tubes in the beezar.com PCB SSMH. The only thing you'd need to do is swap R2 and R8 in the PCB for 390Kohms.
Unfortunately I don't think such an adapter exists, even though I know there are adapters for some popular audio tubes (like this one, for example); so this 19J6 -> 12AU7 adapter would have to be custom built.
Then again, as some previous post suggested, there's also the possibility of re-designing the PCB for the 9-pin 12AU7 socket; but that, of course, is not an easy or quick endeavour.
cheers!
post-6343320
Post #4,528 of 7,240
scompton
post-6343329
Post #4,529 of 7,240
the_equalizer
Aside from TomB's recommendation on checking electronics articles and books, you might want to read this carefully. It might help you understand what do R5/R11 (the cathode resistors) do in the "Starving Student" Hybrid circuit.
post-6343938
Post #4,530 of 7,240
tomb
Looks great! Quote:
What a nice thing to say! Thank you very much.
