smeggy
Member of the Trade: ThunderpantsTP1
- Feb 9, 2004
when do you envision these being in stock?
Originally Posted by tomb /img/forum/go_quote.gif On for 4 hours and the hottest part of the amp measures 37deg. C. (98.6deg.F.). That's right at the root of the heat sinks. The rest of the case measures no more than 33-34deg.C. (91 to 93 deg.F.) I think we have a winner. ![]() |
Originally Posted by tamasic1 /img/forum/go_quote.gif Is your case between between your mosfets and heatsinks? I just have the fets directly on the sinks and they get seriously hot in 10-15min. Can't leave a finger on them but for a sec or two. (Yes, R3/9 right on the leg of fet pin 1) When I rebuild it I'm going for bigger sinks. |
Originally Posted by gurusan /img/forum/go_quote.gif I thought these things were rated for 120C or so? Mine are burning hot to the touch...about 55-60C, but I assumed they were well within the safe temp range? |
Originally Posted by tomb /img/forum/go_quote.gif These are seriously high heat rejectors - they're actually made for TO-3 power transistors. <snip> Since the case is between the MOSFETs and the sinks, you get the added benefit of the case, too. |
Originally Posted by tomb /img/forum/go_quote.gif Warmup is only ~10-20 seconds before you get sound and perhaps a half-hour to an hour for the best listening (less than that if the tubes are well broken-in). |
tomb;5661804 said:
