Absolutely new. I was a little worried that they said they'd "found" a limited edition version in stock which I could have. Was all fine though. The European store is currently showing December as delivery time.
Meze EMPYREAN - the First Isodynamic Hybrid Array Headphone
- Thread starter MezeTeam
Is the limited with copper grills?
Yes.
Coffee Music
I feel you. I wash and wipe my hand every time before I handle my headphone. I've considered buying a pair of gloves, synthetic leather or something just for handling the Empyrean. It's so precious. But I notice the gap of the mesh is a little wide and hair, dandruff, and the likes can fall in. Seems like a vacuum is the best method to clean without anything touching the headphone.I don't think I'd be getting a vacuum anywhere near my headphones.
I would think with the pads on, how dirty could it get inside past the pads? I would just take off the pads and clean them.
ken6217
You can always send an email to Meze and ask them about how to clean. They have always been responsive when I’ve sent them emails.
So, you are thinking about buying gloves for handling the Empyrean, but at the same time you are able to use vacuum cleaner for them? Really??? I think, you are balancing on really thin ice. I would never put them near the vacuum. Only in case, you would like to destroy them...I feel you. I wash and wipe my hand every time before I handle my headphone. I've considered buying a pair of gloves, synthetic leather or something just for handling the Empyrean. It's so precious. But I notice the gap of the mesh is a little wide and hair, dandruff, and the likes can fall in. Seems like a vacuum is the best method to clean without anything touching the headphone.
Coffee Music
Use the air suction to remove the debris that doesn't belong without ever touching the headphone, The idea sounds good on paper, but you never know...So, you are thinking about buying gloves for handling the Empyrean, but at the same time you are able to use vacuum cleaner for them? Really??? I think, you are balancing on really thin ice. I would never put them near the vacuum. Only in case, you would like to destroy them...
I think that is a brilliantly unorthodox way to destroy your thin planar membrane.Use the air suction to remove the debris that doesn't belong without ever touching the headphone, The idea sounds good on paper, but you never know...
ken6217
I think the best bet for you and the headphones would be medication.
For me, that idea sounds, ehm how to say that... Stupid? Sorry, no offense, but it really is a stupid idea!Use the air suction to remove the debris that doesn't belong without ever touching the headphone, The idea sounds good on paper, but you never know...
Coffee Music
Haha. I do see the concerns and risk but like everything, I'm sure there's a right way to approach this. I can't think of a better idea to get dust n what not outside of the driver. i guess blowing would kinda work but that'd introduce more things. A q-tip might introduce more dust. *shrugs*. This whole time I have in mind one of those small handheld vacuums. Not the one you use for your rugs.
ken6217
So why don’t you keep the headphones in the case it came with when you’re not using it. In addition to that wash daily. I don’t see how it’s possible for anything to get into the headphones following and the two above obsessive compulsive behaviors
racebit
- Mar 7, 2016
For removing dust from the drivers I suggest... ...playing music.
The shaking of the driver membrane will throw dust particles away.
It should work much better with very low frequencies (less than 10 HZ) to allow time for the dust particles to fly away between cycles.
You can use this https://www.szynalski.com/tone-generator/
Don't play too loud as it can damage the membrane. Only loud as comfortable to listen too.
racebit
- Mar 7, 2016
Yes, best method is prevention. Store them in a way they can't get dust, and in divisions with little dust. For example bedrooms have a lot of dust from clothes and our body, when we dress/undress. Sofas are terrible too.So why don’t you keep the headphones in the case it came with when you’re not using it. In addition to that wash daily. I don’t see how it’s possible for anything to get into the headphones following and the two above obsessive compulsive behaviors
